I see there are no pre-set amounts, how much is a "standard" donation to like a rom developer?
no actually I left mine plugged in the whole time.... how long was it hung up on the Evo screen before you decided to pull the battery?Thanks for asking Luigic, I don't know if I did the last part of it right. I had it still plugged in when I did hboot and did battery wipe, then rebooted and it hung up in the evo white startup screen. Had to do battery pull rebooted into recovery wiped cache and dalvik-cache, then rebooted and was back up and running. After that I did regular reboot with no problems so I think I should have unplugged before doing last step of battery wipe correct?
umm.. for about 6 mins. but it felt like 20mins lolno actually I left mine plugged in the whole time.... how long was it hung up on the Evo screen before you decided to pull the battery?
ok I will try it again leaving it plugged in through the whole process including the reboots correct?Awesome thanks for the replies everyone!
Hunterbeav I would try again, I'm not sure why that happened to you
k thanksyes should only be 1 reboot.
1.charge to full with green light, then take it off and use the phone for a few mins, then charge back to green light. then turn off phone while still plugged in and let it bump charge for a little while.
2. boot into hboot, choose recovery
3. wipe battery stats, reboot , all while plugged in
Give me 3 bucks and it's all Free.
I love those commercials.
