Dorimanx kernel - Dummies Guide
Any opinions about 7.45 ? I`m still on Siyah 6.0b4 and can`t complain so i`m just wondering is Dori 7.45 worth flashing as 7.44 was giving me troubles...
7.44 gave me some issues as well. I have been on 7.45 for about 12 hours so far and I haven't had any issues so far.
Did you use the kernel wipe in post #1?
Hi Ironass, yeah always run the kernal wipe script, install new kernal, reboot into recovery then fix permissions. I'm running stock 4.0.4 so it's just the kernal I've been playing with on my phone. Went back to 7.43 and all is well so not sure what is playing up on 7.45 on my S2. If you have any other suggestions to try I'd be grateful :)
Don't worry amoxitine, its not just you having a problem booting up on v7.45 on ICS. It is a problem that Dorimanx has acknowledged and intends to fix. See, here.
All I can suggest is to revert to an earlier version for the time being.
New Dorimanx 7.46 is out :)
Kernel 7.46 is ONLINE!
Now read this 2 times!
This kernel is beyond any known kernel for Android devices!
I have updated the SCHED CORE to 3.8.RC5 last update!
Alucard updated the CPUFREQ code from 3.8.RC5
So, if some OLD ROM will be broken, i cant help! UPDATE already! :)
Tested on SAMMY ROM and RootBox 3.2 AOKP works great!
CM10.1 ROM is broken with my kernel, WIFI bugs and others,
So i hope it's will be better now, if not.. well i hope it will one day.
When CM do some more fixing :) they always do, and that is great!
Change Log:
*ROOT (SuperSU) updated to 1.04 and will replace any other by auto.
*Kernel Sched Core merged with 3.8.RC5 kernel main line. (70 Commits!)
*Kernel CpuFreq code merged with 3.8.RC5 exonys part.
Now CPU voltage is lower by default on each freq! so be careful with UV
if you still do that! that is NOT SUPPORTED! dont post about it.
*Fixed HOME KEY restore (for JB SAMMY ONLY!) if switching to other kernel via RECOVERY.
*Tuned All Profiles.
*Alucard tuned and updated! Nightmare GOV to be something Awesome!
it's very powerful and low draining=(on idle!) if used it's give you the smoothness that you like, it's tuned based on profiles.
*Fixed ICS BOOT stuck! now BOOT.
*Added Auto Fix to EFS partition holding the important Device files. if it's get broken, you loose signal + others things, now it's will not happen.
FIX will be auto when you load RECOVERY and only if needed. no user input required.
*Added CLEAN RAM CACHE button to STweaks Memory TAB. it's can clean very fast all cached RAM, it's will be filled slowly again.
*Restored normal color for Recovery.
*Reduced Logger allocated RAM and restored PMEM = 4MB allocation for ICS and JB SAMMY, it can improve stability, we lost 2MB of TOTAL RAM.
*Removed broken sched_mc_power_savings it's was 0(disabled) and was holding huge code! now it's out! and battery drain is very low. :)
*Updated Sensors Code from JB SAMMY Kernel.
*Ported MMC code updates to support 16GB+ cards from unsupported vendors, now should work. thanks to AndreiLux! :)
also should help with sdcard error detection.
have fun and report :)
Please post things that belong to DEV thread. no junk posts.
We dont want to CLOSE this thread and open on Updates.
Development thread = Development posts and ideas. no questions!
Thanks a lot.
D-TEAM.
SIGNATURE
PHONE : SGSII
Sent via: Tapatalk 2
Main ROM: AllianceROM v6 LS8
KERNEL : Dorimanx 7.45
(DEFAULT PROFILE AND SETTINGS )
MODEM : LS8
BATTERY : Stock 1650mAh
EXTERNAL Sdcard : Samsung Class 10 32gb
LAUNCHER : Apex
THE CAVE = My Guides list to install NeatRom and other ROMS and kernels on LSJ and LS8 + tools to have a bug free rom and kernel + how to back up and RESTORE ROM OM FULLY = http://forum.xda-developers.com/showthread.php?p=35923600
1.Current list of kernels on LSJ and pros and cons
http://forum.xda-developers.com/showthread.php?p=36698607
2.Rom Nuke / Wipe scripts
http://forum.xda-developers.com/showthread.php?p=36742265
3. GS2KERNELWIPE script
http://forum.xda-developers.com/showthread.php?p=36742198
4.Fast Dormancy :
http://forum.xda-developers.com/showthread.php?p=36396636
5. How to install full wipe with rom nuke on LSJ
http://forum.xda-developers.com/showthread.php?p=36655790
Just suggesting that 7.46 fixes/tweaks didn't fix this up, noting your suggestions on a workaround etc. thanks for your support.... I think.
I know but no point in bringing it up unless it says in change log its fixed right? . You might as well mention preload is not backed up or duel boot not working then.
It a well known issue to Dorimanx so he will make that a point in saying that it's fixed. So for further releases don't expect it to be fixed until he says it's fixed. ;)
Had a bit of a disaster after installing 7.46....all appeared to be well for a couple of hours, but then noticed that the Wifi wasn't working so well (in the 'on but not connecting' state) so I rebooted my phone and after that it wouldn't boot past the Dorimanx logo. Tried everything to fix it (reflashing v7.43 which has been fine for me and also tried Siyah which got me out of a jam when I installed 7.45) but I just couldn't get the phone to boot up.
Decided to instead take the plunge and install Neat Lite rather than trying to source the stock ROM and ran a Titanium restore so I now have a working phone again. Just thought I'd mention this as a heads up (I was running stock 4.0.4) in case there is an issue with this release. I'm gonna drop Dorimanx a line on XDA to let him know what happened to me, as it's the first time I've experienced a permanent non boot (aside from v7.45)
Dori 7.47 is now up:
Kernel 7.47 Power BETA online!
Please READ change log x2!
Change Log:
*Updated WiFi driver from 1.12.19 to 1.12.23 from Google Exonys Kernel.
should sleep and work as should!
NOTE: CM10.1 Hotspot ROM drivers not supported! so it's will not turn ON.(the HOTSPOT! wifi OK)
for all the rest OK.
*Updated with 3.0.62 patch from main stream.
*Updated kernel build scripts from 3.8.RC6 kernel.
*Pulled all new MEM updates from 3.8.RC6 kernel.
*Alucard fixed and tuned Nightmare gov, now sec cpu turn on/off and should!
and gov set as default for profiles: default, performance, and extra performance.
*All profiles tuned!
*We have cleaned CPU code and improved voltages now we are +25mv from default exonys cpu voltages,
we have tried to use DEFAULT, but found it to be unstable in some conditions! "SOD" now stable.
*I have added new control for dirty ratio in Memory tab and STweaks.
*Fixed touch keys ON if user want OFF. now will be OFF.
*Fixed "AFTR only" set by auto for JB SAMMY ROMS to remove sound bug on screen off.
*Improved wake up boost function for nightmare gov, now kick ON with full power for set delay, then go to normal mode.
*Alucard fixed the 1.6Mhz freq spike on boot that broken many phones boot in last kernel, now we have less voltage wasted and no 1.6Mhz spikes!
many CPU chips cant handle that speed even for 0.1 sec! (cpu code tuned to more battery saver, pulled from 3.8.RC6)
*Voku ported Network updates that should speed up network processing + security + lower battery usage.
*Voku ported code for improved file Mem cache to speed up the system.
*Voku ported lowmemkiller code to work with better values taken from actual RAM.
*Voku ported updates to ROW I/O sched, it's should work better and save some power on idle.
*I have ported update to NEW MALI drivers from JB-KERNEL source. effect only CM10/10.1 and all AOKP ROMS. (nothing to pull for old driver!)
*Added DB optimization Cron task and fixed others. (will run at 3:00AM if checked)
*Alucard made many corrections in STweaks descriptions, tuning + cleaning!
*I have fixed SuperSU PRO app removed on ROOT reinstall or update!
this is paid app that allow more options in SuperSU ->"free ver", see Google play. (not must to have, but nice)
*I have tuned static memory tuning in cortex.
*Cortex FW tweaks set PING blocked or allowed! nothing more.
if you need ping open uncheck the cortex fw and reboot.
I've been running this kernel all day (extreme_battery defaults) and it's looking good. 1.4%/h battery drain, 90% deep sleep and no issues to bleat about. I haven't yet checked on whether the audio issue has indeed been fixed, or if video streamed from my NAS still stutters like IA after one dram too many. :D
Flashed 7.47 before I headed to the gym, stuck my running playlist on and... IT AIN'T FIXED! :rolleyes:
Audio issue that is...
Change Log:
*Updated WiFi ....
... *Cortex FW tweaks set PING blocked or allowed! nothing more.
So, no bold, 3", lettering in title or smiley face... no download link or source link.
Very slap dash, slip shod and lackadaisical if you ask me Hawker!
8/10 Could try harder. ;)
Strange!
After a good night on NEAT ROM LSD, amended, full and PhilZ kernel, 4.22, I thought I would give Dorimanx 7.47 a go. Used the GS2KernelWipe and flashed Dori kernel, which started to boot but went to a black screen after the Dori logo and just sits there. If I touch the soft keys, they illuminate but nothing else. Re-booted into Recovery and manually wiped cache, dalvik and fixed permissions before re-flashing Dori... same result!
Anybody else getting this?
(Syd... you haven't put the K.o.D. on it have you? :vamp: )
Strange!
Can't blame me this time old stick. For me siyah remains faultless with great battery so not even bothering to try new dori releases these days.
TBH, I have not found, for me, either Dori 7.46 or 7.47 that good. Have been getting all sorts of wakelocks and poor battery life.
I may just give the, "master", gokhanmoral a go... if you haven't q u e e r e d-the-pitch! ;)
Update... flashes Siyah v6.0beta4, OK!
You really are a cultured, well heeled sort of chap. Never heard that one before, like it
