Requires root
I took the droid 2 swype keyboard theme and put it into an xml for metamorph. (credit to sneaky_zekey for the original file and making this possible, thanks!)
Sneaky_zekey has a lot more swype themes available that can be found here.
If you don't have swype, you can register for the beta here. (thanks OMJ)
Droid 2 Swype Theme for Metamorph
If link is down, download is attached at bottom of first post here.
1. Download the zip from the link above and move it to your sdcard
2. Open Root Explorer or use ADB to get to /data/app
3. In data/app find com.swype.android.inputmethod-1.apk, long press and move (make sure droid is set to read/write)
4. Move the apk into /system/app
5. Rename to "swype.apk" exactly like that
6. Reboot the phone
7. Install MetaMorph from the market
8. Open MetaMorph and choose Unzip/Extract
9. Find the file named SwypeBlack_blue_keys.zip
10. Choose Apply Theme after it extracts
11. Reboot your phone and you're done!
6. Reboot the phone
