What a bummer. I couldnt even get the factory reset to successfully complete, I had to pull the battery out and turn it on a couple minutes later for it to even get to the main screen. Does this happen when charging? If so, you are most likely using an improper charging source. For instance, if you attempt to use a blackberry storm charger (which fits) an incorrect amount of power will be sent to the phone, causing it to restart.
