Root Droid X 2.2 Overclock (Kernel Module w/Instructions)
I feel so noobish
What script? LOL
Well I executed the 100.sh file and I get massive 694 :(
well second run gets 1308
Now what? How do I start jacking it up or down?
Your setscale script. You can use root explorer to change the values, the setscale.sh file is in system/xbin. Once you've edited it press on it and select "execute".
OK, a few quick questions.
(I've gotten everything working before. Got up to 1.4GHz for about 5 minutes)
Is there a way that I dont have to do this part everytime is reboots:
Code:
$ su
# cd /sdcard/extracted/droidx_22_oc (or wherever you extracted the files to)
# mount -o rw,remount -t ext3 /dev/block/mcblk1p21 /system
# cp overclock.ko /system/lib/modules/overclock.ko
# cp setscaling.sh /system/xbin/setscaling.sh
# chmod 644 /system/lib/modules/overclock.ko
# chmod 755 /system/xbin/setscaling.sh
It gets really obnoxious after a while. (Having to redo it every time)
I also had something wierd happen.. I ran 1.1 fine, got up to 2.2 fine. jumped to 1.4, and an semi-instant crash.. did it again, it ran longer. I tried 1.3, and it was an instant crash as well. (trying to get into setCPU) Is it odd that 1.4 worked longer than 1.3?
Also, can someone maybe do a quick write up on the setscaling script? I get what is the GHz and whats the Voltages, but can someone explain a little more indepth how they interact, and what changing them will do? (obvoiusly lower V is more batterly life, but more in depth?)
Ok so I just have to edit the setscaling100.sh (for me anyways others might have the setscaling.sh) then execute. Once I think it's stable I can do the other -recovery command to make it stick on reboot?
What's the best way to test stability? using setcpu? and where do I find what speed my phone is currently running at?
If I use setcpu autodetect and I check "set on Boot" will these setting stick? It seems to be reading the setting I've given it so I assume that would work?
Ok i've got a question. My phone is stable at around 1.225 with these settings
echo 65 > /proc/overclock/max_vsel
echo 1225000 > /proc/overclock/max_rate
echo 1 400000000 27 > /proc/overclock/mpu_opps
echo 2 700000000 38 > /proc/overclock/mpu_opps
echo 3 900000000 45 > /proc/overclock/mpu_opps
echo 4 1225000000 65 > /proc/overclock/mpu_opps
echo 0 1225000 > /proc/overclock/freq_table
echo 1 900000 > /proc/overclock/freq_table
echo 2 700000 > /proc/overclock/freq_table
echo 3 400000 > /proc/overclock/freq_table
Now if I just change to 1300,without changing anything else it starts to turtle. never reboots just goes really slow. If i were to tweak my settings should I raise or lower the voltages of the other echoes? Whats the difference? What i'm asking is, if your phone turtles does that mean you should raise voltage? Or is it all just crossing your fingers?
Code:
$ su
The only commands you need to run each time are:
insmod /system/lib/modules/overclock.ko
setscaling.sh
You can use the gscript app to save the commands and then just one press will execute them for you.
raise the voltage first.
It's been running for 24 hours now with no reboots. Here is the scale that I've using.
echo 1400000 > /proc/overclock/max_rate
echo 1 300000000 30 > /proc/overclock/mpu_opps
echo 2 700000000 34 > /proc/overclock/mpu_opps
echo 3 1000000000 45 > /proc/overclock/mpu_opps
echo 4 1400000000 65 > /proc/overclock/mpu_opps
echo 0 1400000 > /proc/overclock/freq_table
echo 1 1000000 > /proc/overclock/freq_table
echo 3 300000 > /proc/overclock/freq_table
fuuuuuuu wish i cud get these settings to work
OK I am confused, and new to the adb or terminal thing.
These commands, are they entered on the phone, or are they entered by computer connected to the phone. What do I need on the phone and on the computer?
is there terminal emulator on the phone itself? I suppose the build props work the same way. I had trouble loading those last night too.
Code:
echo 68 > /proc/overclock/max_vsel
echo 1 400000000 30 > /proc/overclock/mpu_opps
echo 4 1400000000 68 > /proc/overclock/mpu_opps
Stable for 19 hrs now with no reboots. Battery life is awesome with moderate to heavy use for about 4 hrs yesterday. Started with 80% and sitting at 30% now.
You've increased your voltage by 11% at the bottom end and by 16% at the top. That with the 40% overclock at the top end (and the fact that the processor spends nearly all it's time at either the top or bottom, I'm wondering how this'll translate into battery life. Since you're our intrepid pioneer here, let the rest of us know how it's working out, will you?
I bumped up to 1.45 GHz this morning and so far so good (3.5 hours). I charge my phone at night when I go to bed so as long as it can make it through a 16ish hour period I'm happy with it. The battery life has been fine so far.
Edit: 1.45 just crashed, back to 1.4 for now.
Code:
$ su
I've noticed that when using cmd, all of the commands in adb get saved. This makes is really easy to repeat the code to try out different settings. This is what I do:
  • 'adb shell'
  • Follow the steps in the OP using whichever settings you prefer.
  • Unplug the phone and keep cmd open. (or you can just hit 'exit' twice, however you prefer to get out of shell.)
  • Once you are ready to try a different setting out, plug the phone back in. (if you chose to unplug it.)
  • Do 'adb shell' again..
  • Once you are there, hit the up button repeatedly and it will scroll up through all of the commands... Once you get to 'su', hit enter.
  • Now you can press down, enter, down, enter, etc, to run through the commands easily.
  • After the second run, unplug the phone again. (or 'exit' twice.)
  • From now on, as long as you keep cmd open (from the third time on), after you are in 'adb shell', just press the down button and it will run through (you won't have to scroll up through the commands anymore.)
This will let you run through the entire thing without having to copy all that again.
One important thing to note is that if you don't reboot the phone, you will have to throw in the command 'rmmod overclock.ko' otherwise you will get an error saying it already exists.. I enter this in right above 'insmod /system/lib/modules/overclock.ko'. Do this the first time to make it easy on yourself. It WILL give you an error the first time, just ignore this and keep going, this way it is saved for the rest of your attempts.
Hope this helps.. I'm sure there are easier ways, but if you are using adb, it will make it a breeze. (This is all Win 7, dunno if that matters.)
setscale.sh
So even though it resets the setscale every reboot, it saves all of the copies from the other commands? So i can just push a new set scale to my /xbin/ and then run insmod and the script? Sweet. Thanks.
There is no reason to run all those commands again.
After you edit the setscaling.sh or setscaling100.sh you only need the last two commands.
adb/terminal:
$ su
# insmod /system/lib/modules/overclock.ko
# setscaling.sh
OR...
adb/terminal:
$ su
# setscaling100.sh
I am unable to find a way to view the file to alter...(meaning I cant get into the script file)
You need to use root explorer, the script file is located in the system/xbin folder. Change the r/o (top right of the screen) to r/w, then long press on the file and scroll down to edit.
Would I be crazy to flash sbf back to 2.1, then ota 2.2, reroot, reinstll fission, reset everthing to my settings, then finally try overclocking past 1.15 lol? Debating if its worth it?
