Milestone Overclock as of version 1.4.3 now officially supports Droid X/2 running 2.2/Froyo. Go download it for FREE from the Market. Here is a a post from Tiago from the DroidXForums thread.
Side Note:
The Milestone Overclock kernel module is at the core of all other Droid X/2 overclocking "apps". I'd prefer to call them "Alternate User Interfaces" or "Skins" to the Milestone Overclock kernel module. If you appreciate the ability to overclock your Droid X/2, please Donate to Tiago!
Instructions:
Download Milestone Overclock from the Market, and give it a whirl.
The app is geared towards providing the basics, in a safe manner. It has brick protection, where if you happen to input a custom setting that is out of spec, and causes you to bootloop, you can pull your sdcard and get into your phone to clear the settings...
Full control of freq/vsel still requires a setscaling.sh script(that's how the cool folks like to do it anyways). Pull that from the original zip file. I'll update that when I get a chance.
Original Post:
Hi all, I'm the Milestone Overclock guy. I'd like to let you know that the latest version of Milestone Overclock supports Droid X 2.2 and is now in the Market. It is based on the fix by nadlabak/kabaldan but done "correctly" now that we have the kernel source.
Note also that this fix should correct the vsel problem that many had in android 2.1. The previous module/app simply wasn't setting vsel at all, as many of you suspected. Let's hope this version takes care of it, for anyone that didn't upgrade to 2.2.
For those of you not familiar with Milestone Overclock, it's the original overclock app for the Motorola Milestone (which has a locked firmware just like the Droid X) but nowadays strives to support all OMAP3 phones, and that includes Droid, Droid X, Droid 2 (working on it), many XT7xx/XT8xx and even a Samsung (Galaxy Beam; others are Hummingbird, not OMAP). And yes, it's free!
If you're interested, you can check out the issue which led to this release in the project site:
Issue 36 - milestone-overclock - Modify Source to Support Droid X. - Project Hosting on Google Code
(many thanks to tekahuna)
Thanks
Tiago Sousa aka mirage
Side Note:
Instructions:
Original Post:
Milestone Overclock Module 1.2t (nadlabak's patch) w/ Memory Locations for DroidX 2.2 Added by FreeWELL
Credits:
Tiago Sousa aka Mirage: for The Milestone Overclock Project
nadlabak: for patching in Froyo/2.2 Support
FreeWELL: for finding DroidX 2.2 memory locations/module compilation
Notes:
I'm trying to keep this as close as possible to the way it was done on 2.1. For me, 2.2 seems to need a little more voltage to be stable than it was under 2.1. I've included two versions of setscaling.sh to start from.
setscaling.sh is set to stock voltages/clock speed
setscaling100.sh is set to stock voltages w/100mhz bump accross the board to 400/700/900/1100 (This appears to be stable for me, and is the baseline for my testing/tuning)
Install Instructions
adb/terminal:
$ su
# cd /sdcard/extracted/droidx_22_oc (or wherever you extracted the files to)
# mount -o rw,remount -t ext3 /dev/block/mcblk1p21 /system
# cp overclock.ko /system/lib/modules/overclock.ko
# cp setscaling.sh /system/xbin/setscaling.sh
# chmod 644 /system/lib/modules/overclock.ko
# chmod 755 /system/xbin/setscaling.sh
<optional(only do after thoroughly testing what works for your DroidX in setscaling.sh)>
# cp install-recovery.sh /system/etc/install-recovery.sh
# chmod 755 /system/etc/install-recovery.sh
</optional>
# mount -o ro,remount -t ext3 /dev/block/mcblk1p21 /system
Run Instructions
adb/terminal:
$ su
# insmod /system/lib/modules/overclock.ko
# setscaling.sh
