Root Droid X is possibly bricked
8-Bit-Soldier
My Droid X is bricked I think :( Can anybody help me out? I was originally running Liberty and I wanted to install the .595 Gingerbread ROM, so I went into my sdcard dropped the .595 (deodexed as well) and deleted the Liberty ROM, it loaded fine but now I'm stuck at the boot up and it keeps flickering. What do I do?
1. Calm down
2. Learn to read directions
3. SBF back to a clean froyo install
4. Come back and we will help you get on Gingerbread :D
Before you SBF try this. Plug your X into the computer and it will boot into CWM recovery. Wipe data and factory reset. Without leaving recovery flash your .595 zip. Hopefully you will boot into .595 fresh. I was not running Libery 2.0 but was on .588 and went straight to .595 and also ended in a boot loop.
computer can't even recognize it so SBF is looking like my best bet
my d x blinks the moto m on and off repeatedly. i need to find a way of combonation of keys to push to bring me back to clockworkmod. i was putting blur version 2.3.3 on it and it was a 2 part install and i put the 2nd part on before the first like a dummy. need help please
Hold the volume + camera + power button until the screen lights up. Then let go. What you see is your bootloader screen.
FOLLOW THE INSTRUCTIONS for SBFing.
2 other people have already told you to read about how to do this. What you were doing when it happened is irrelevant at this point. If you want your phone fixed, this is how you need to do it.
So calm down, take a breath, READ THE INSTRUCTIONS in the link below, follow them, get your phone working again.
SBF’ing the Droid X U D G
