Root Droid X ROMs and Themes
Status
Not open for further replies.
D13 in
updated with drop theme, also let me know if any of the links die for whatever reason
FYI that Drop theme look just like the one in ROM Manager. On its Onix so I guess it is.
yeah it is but I didn't just want to say go get it in rom manager
Actually I will add if it is available in rom manager or not
I am loving the Black Glass X theme by 928Droid with the red theme Swype keyboard from XDA Developers. I have installed the deodexed version for Froyo and it is sweet! Themed lockscreen, widgets, multi-touch keyboard, status bar, static wallpaper and live wallpaper. Matching ADW launcher available in separate file.:D
I thought Black glass was 2.1 theme. I wanted to try it but the only link I found that worked was under the section that said 2.1 ONLY!
I've been running it also on my deodexed 2.2 but I didn't like the battery percentage in the notification bar so I used a different set of images to change it.
HERE is the page where you can select which download you need.
Thanks Air. I did go back and look around and finally found the one we X'ers needed. It wasn't easy that guys site is way to busy and lots of stuff looks like links but are just underlined text. Drove me crazy/er :D But I think I finally found the correct one. If it's not I'll be using your link for sure.
Thanks again
quick question.. im working on my friends droid x and its rooted 2.1 , can i just install the Fly X rom over on the 2.1 or do i have to go to 2.2 like i did on my x?
DO NOT install flyx over 2.1. You MUST be on 2.2 already or you will bootloop or best case scenario it won't take.
Do you have to wipe data/cache when installing the .zip file of the Galaxy S theme from bobrowitz or whatever? I'm running FlyX v0.1 now with no themes installed.
2.3.13 with bloatware removed (I've removed 70 apps) has been amazing for me, I'm getting high quadrant (1500+)and linpack (14.4+) scores and the phone seems faster and smoother than it has in the past.
Status
