Droid X Simulator
Just found this on the site. If you are new to android I would suggest playing around with it.
Droid X Simulator
Hey man, where can I find this simulator?? I opened yours once and the following day it seems like all three components are scattered about on the page. It's prob my pc. but still I need to find it elsewhere. Thanks.
Go to verizonwireless.com then click the support tab at the top. Then pick your device and click on "interactive 'how to' simulator" under "Support for your phone".
See if that helps any.
Thanks. Coming from a Storm and will get the Droid sent from Verizon(??) and I can play with that until it comes in. Will help my 'learning curve' a bunch!
