Elektra mid 9762 tablet comments
Hi.
Today I bought Elektra mid 9762 tablet (Chinese), I installed google play but could not be launched, it just stack on desktop, also it seems it is not supported by google play.
I have a chance to return it back and got my money back in hours.
Please comment.
Good luck.:o
Hi LilBit
You are right, my opinion is if it works I will keep it because it is 25% of Samsung one price but if it is not it will be useless.
Problem I have no time to try and find out the way to have it worked.
Thanks for comment.:D
If you are not happy with it, then by all means return it. It's your money and happiness that matter.
As the not so proud owner of an off brand tablet I can honestly say with out question you should TAKE IT BACK. Get something reliable and that works with Google Play. I have since bought a Nexus 7 and couldn't be happier with the Nexus. It works and its as cheap as most of the Off brands are. I wish I would have gotten it originally.
