Build: verizon_lge/cayman_vzw_us/cayman:2.3.6/GRK39F/VS840ZV5.47B7D6E6:user/release-keys
Hardware: lge_cayman
Bootloader: unknown
Radio: unknown
Kernel: Linux version 2.6.35.11-perf (lge@android-build) (gcc version 4.4.3 (GCC) ) #1 SMP PREEMPT Fri Mar 23 04:46:18 KST 2012
[ 0.620673] hw perfevents: enabled with ARMv7 Scorpion-MP PMU driver, 5 counters available
[ 0.622547] Scorpion registered PMU device
[ 0.623077] pm8058_init: i2c_add_driver: rc = 0
[ 0.623202] pm8901_init: i2c_add_driver: rc = 0
[ 0.625108] pm8058_probe: PMIC revision: E3
[ 0.627093] pm8901_probe: PMIC revision: F4
[ 0.629699] pm8058_gpio_probe: gpiochip_add(): rc=0
[ 0.630333] pm8058_mpp_probe: gpiochip_add(): rc=0
[ 0.637427] bio: create slab <bio-0> at 0
[ 0.638000] pm8901_mpp_probe: gpiochip_add(): rc=0
[ 0.638673] pmic8058_pwm_probe: OK
[ 0.638986] SCSI subsystem initialized
[ 0.639185] usbcore: registered new interface driver usbfs
[ 0.639415] usbcore: registered new interface driver hub
[ 0.639647] usbcore: registered new device driver usb
[ 0.640223] Advanced Linux Sound Architecture Driver Version 1.0.23.
[ 0.640646] Bluetooth: Core ver 2.15
[ 0.640857] NET: Registered protocol family 31
[ 0.640954] Bluetooth: HCI device and connection manager initialized
[ 0.641134] Bluetooth: HCI socket layer initialized
[ 0.641321] Switching to clocksource dg_timer
[ 0.645389] NET: Registered protocol family 2
[ 0.645636] IP route cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.645910] TCP established hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.646826] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.647725] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.647822] TCP reno registered
[ 0.647921] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.648032] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.648391] NET: Registered protocol family 1
[ 0.650130] RPC: Registered udp transport module.
[ 0.650231] RPC: Registered tcp transport module.
[ 0.650407] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.650655] Trying to unpack rootfs image as initramfs...
[ 0.721613] Freeing initrd memory: 1456K
[ 0.721962] PMU: registered new PMU device of type 0
[ 0.722449] ETM/ETB intialized.
[ 0.722549] sdio_al:SDIO-AL SW version 1.30
[ 0.724970] Error: Driver 'SDIO_CIQ_TEST' is already registered, aborting...
[ 0.728401] msm_dsps driver version 1.03.
[ 0.733320] charm_modem_probe: Registering charm modem
[ 0.735884] msm_rpm_log_probe: OK
[ 0.736084] [sdio_debug_init] ++
[ 0.736332] [sdio_debug_init] successfully registered SDIO device[sdio_debug_init] --
[ 0.736958] diagcmd_probe:lg_fw_diagcmd
[ 0.737704] input: ats_input as /devices/virtual/input/input0
[ 0.737958] lge_emmc_direct_access_init: finished
[ 0.738398] lge_tempdevice_init
[ 0.738905] [miracle.kim] Mt9p017.c : mt9p017_init
[ 0.739150] [miracle.kim] Mt9p017.c : __mt9p017_probe
[ 0.739278] msm_camera_vreg_enable:
[ 0.740197] Mt9p017.c : mt9p017_sensor_probe
[ 0.791546] Mt9p017.c : mt9p017_sensor_probe - complete : 0
[ 0.791720] msm_camera_vreg_disable:
[ 0.792808] msm_camera_vreg_enable:
[ 0.793576] msm_camera_vreg_disable:
[ 0.794708] lm3537_probe: i2c probe start
[ 0.806071] mipi_lgd_lcd_probe: mipi lgd lcd probe start
[ 0.806172] setting pdata->panel_info.fb_num to 3. type: 8
[ 0.806516] sensor_common_power_set pwr_mask(0), on(1), sensor(1)
[ 0.809052] k3dh_acc_misc Device detected!
[ 0.809381] k3dh_acc_misc I2C driver registered!
[ 0.809925] input: accelerometer as /devices/virtual/input/input1
[ 0.810217] input: gesture_tap as /devices/virtual/input/input2
[ 0.810425] input: gesture_flip as /devices/virtual/input/input3
[ 0.810801] sensor_common_power_set pwr_mask(1), on(0), sensor(1)
[ 0.811363] sensor_common_power_set pwr_mask(0), on(1), sensor(4)
[ 0.813187] input: gyroscope as /devices/virtual/input/input4
[ 0.813288] sensor_common_power_set pwr_mask(4), on(0), sensor(4)
[ 0.814029] sensor_common_power_set pwr_mask(0), on(1), sensor(2)
[ 0.815822] ami306 11-000e: force operating mode
[ 0.816001] Register input device!
[ 0.816216] input: magnetic_field as /devices/virtual/input/input5
[ 0.831517] apds9900 11-0039: enable = 0
[ 0.831618] power_set_for_8058_l15: prox/als power line: 4145, onoff(1)
[ 0.842502] apds9900 11-0039: support ver. 1.0.4 enabled
[ 0.842833] input: proximity as /devices/virtual/input/input6
[ 0.843125] input: light as /devices/virtual/input/input7
[ 1.251625] input: synaptics_ts as /devices/virtual/input/input8
[ 1.255627] [Touch] UNLOCK
[ 1.255832] [Touch] Synaptics TM1992-001(Interrupt mode): ID[1], FW rev[4], f/u[0]
[ 1.255931] [Touch] irq_pin[1], next_work[0], baseline state: 0
[ 1.256235] Loading pn544 driver
[ 1.256393] testmode_init
[ 1.256640] testmode_probe
[ 1.256968] [Touch] FW-upgrade is not executed
[ 1.361731] input: atcmd_virtual_kbd as /devices/platform/atcmd_virtual_kbd/input/input9
[ 1.362359] lge_panic_handler: got buffer at 42d80000, size 40000
[ 1.374193] highmem bounce pool size: 64 pages
[ 1.374527] ashmem: initialized
[ 1.392022] Slow work thread pool: Starting up
[ 1.392221] Slow work thread pool: Ready
[ 1.392409] msgmni has been set to 621
[ 1.413602] alg: No test for stdrng (krng)
[ 1.413829] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 1.414013] io scheduler noop registered
[ 1.414111] io scheduler deadline registered (default)
[ 1.414293] io scheduler cfq registered
[ 1.420849] mipi_dsi base phy_addr = 0x4700000 virt = 0xe1b00000
[ 1.421029] msm_mmss_cc base = 0xfa014000
[ 1.421131] mmss_sfpb base phy_addr = 0x5700000 virt = 0xe1874000
[ 1.421322] mipi_dsi_probe: vsync_gpio=0
[ 1.424975] FrameBuffer[0] 480x800 size=4608000 bytes is registered successfully!
[ 1.426681] Registered led device: lcd-backlight
[ 1.427393] msm_vidc_dec: Inside vid_dec_init()
[ 1.427617] msm_vidc_dec: Inside vid_dec_vcd_init()
[ 1.427889]
[ 1.427892] msm_vidc_enc: Inside vid_enc_init()
[ 1.428261]
[ 1.428265] msm_vidc_enc: Inside vid_enc_vcd_init()
[ 1.572140] msm_serial_hs.0: ttyHS0 at MMIO 0x16540000 (irq = 188) is a MSM HS UART
[ 1.572945] msm_serial_hs module loaded
[ 1.573129] msm_serial_hsl: detected port #1
[ 1.573271] msm_serial_hsl.1: ttyHSL1 at MMIO 0x19940000 (irq = 221) is a MSM
[ 1.573847] msm_serial_hsl: detected port #0
[ 1.573996] msm_serial_hsl.0: ttyHSL0 at MMIO 0x19c40000 (irq = 227) is a MSM
[ 1.574632] msm_serial_hsl: driver initialized
[ 1.578340] brd: module loaded
[ 1.580398] loop: module loaded
[ 1.580642] pmem: Initializing pmem_kernel_ebi1 (in-kernel)
[ 1.580787] pmem: Initializing pmem_kernel_smi (in-kernel)
[ 1.580997] pmem: Initializing pmem (user-space) as cached
[ 1.581448] pmem: Initializing pmem_adsp (user-space) as non-cached
[ 1.581835] pmem: Reserving virtual address range e3000000 - e5000000 for pmem_adsp
[ 1.582069] pmem: Initializing pmem_audio (user-space) as non-cached
[ 1.582356] pmem: Initializing pmem_smipool (user-space) as non-cached
[ 1.582697] pmem: Reserving virtual address range e6000000 - e9a00000 for pmem_smipool
[ 1.583514] pmic8058_upl_probe: OK
[ 1.584203] pmic8058_misc_probe: OK
[ 1.584527] pm8058_batt_alarm_threshold_set: pm8058_batt_alarm_threshold_set : lower_threshold_mV = 4120, upper_threshold_mV = 4200
[ 1.584819] pm8058_batt_alarm_state_set: BATTERY ALARM LOWER SET ENABLE
[ 1.585000] pm8058_batt_alarm_probe: OK
[ 1.590603] adie_codec_register_codec_operations: codec type 1
[ 1.601981] SCSI Media Changer driver v0.25
[ 1.602167] SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
[ 1.602346] CSLIP: code copyright 1989 Regents of the University of California.
[ 1.602700] brcm_static_buf_init: initialize wifi_alloc_data
[ 1.602887] Section [3] initial allocation success size[139264]!!!
[ 1.603064] Section [2] initial allocation success size[32768]!!!
[ 1.603162] Section [1] initial allocation success size[12288]!!!
[ 1.603340] Section [0] initial allocation success size[12288]!!!
[ 1.603464] rmnet_init: SMD devices[8]
[ 1.606791] rmnet_init: SDIO devices[8]
[ 1.611985] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.612243] host driver registered w/ tranceiver
[ 1.612551] usbcore: registered new interface driver cdc_acm
[ 1.612649] cdc_acm: v0.26:USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.612827] Initializing USB Mass Storage driver...
[ 1.612964] usbcore: registered new interface driver usb-storage
[ 1.613141] USB Mass Storage support registered.
[ 1.613268] usbcore: registered new interface driver usb_ehset_test
[ 1.613665] peripheral driver registered w/ tranceiver
[ 1.614137] android_usb gadget: android_usb ready
[ 1.614531] fserial_probe:gport:tty_ports:0 sdio_ports:1 smd_ports:1 nr_ports:2
[ 1.614633] android_register_function: modem 1 6
[ 1.614923] atcmd_init: ATCMD Handler /dev/lge_atcmd major=237
[ 1.615368] seunghun.kim : f_adb init
[ 1.615549] android_register_function: adb 2 6
[ 1.615875] android_register_function: usb_mass_storage 3 6
[ 1.616053] f_ecm init
[ 1.616150] android_register_function: cdc_ethernet 4 6
[ 1.616337] android_register_function: diag 5 6
[ 1.616576] android_register_function: diag_mdm 6 6
[ 1.617285] daniel.kang gport_setup (0): no_tty_ports:0 no_sdio_ports:1 no_smd_ports:1 nr_ports:2
[ 1.617469] gser_bind_config: serial ctrl status 4
[ 1.617566] gser_bind_config: serial data status 5
[ 1.617928] android_usb gadget: using random self ethernet address
[ 1.618036] android_usb gadget: using random host ethernet address
[ 1.618504] usb0: MAC 5a:ba:2e:9a:1a:7c
[ 1.618603] usb0: HOST MAC 82:32:8c:05:d8:ec
[ 1.618781] ecm_bind_config: iMACAddress = 7
[ 1.620112] DIAG registered SDIO device
[ 1.620713] diagchar initialized
[ 1.623330] input: ffa-keypad as /devices/i2c-6/6-0055/pm8058-keypad/input/input10
[ 1.624803] input: pmic8058_pwrkey as /devices/i2c-6/6-0055/pm8058-pwrkey/input/input11
[ 1.625372] ######## bthid_init: ########
[ 1.625657] ######## bthid_init: done ########
[ 1.626870] using rtc device, pm8058_rtc0, for alarms
[ 1.626990] pm8058-rtc pm8058-rtc: rtc core: registered pm8058_rtc0 as rtc0
[ 1.627380] i2c /dev entries driver
[ 1.629275] IR NEC protocol handler initialized
[ 1.629377] IR RC5(x) protocol handler initialized
[ 1.629552] IR RC6 protocol handler initialized
[ 1.629647] IR JVC protocol handler initialized
[ 1.629821] IR Sony protocol handler initialized
[ 1.629918] Linux video capture interface: v2.00
[ 1.630365] usbcore: registered new interface driver uvcvideo
[ 1.630543] USB Video Class driver (v0.1.0)
[ 1.631576] I2C radio driver for Qualcomm FM Radio Transceiver , Version 1.0.0
[ 1.641767] ############ [msm_charger_temp_work] POLL TIME = 5400 #####################
[ 1.652194] max17040 9-0036: MAX17040 Fuel-Gauge Ver 02
[ 1.652962] msm_adc successfully registered
[ 1.653798] pmic8901_tm_probe: OK
[ 1.654178] ====adc_channel_request_conv: Pm8058 xoadc calibration
[ 1.691509] pmic8058_xoadc:The offset for AMUX calibrationwas -464
[ 1.696253] pmic8058_tm_probe: OK
[ 1.711510] tsens_tm_probe: OK
[ 1.712112] device-mapper: ioctl: 4.17.0-ioctl (2010-03-05) initialised:
dm-devel@redhat.com
[ 1.712320] Bluetooth: HCI UART driver ver 2.2
[ 1.712495] Bluetooth: HCI H4 protocol initialized
[ 1.712592] Bluetooth: HCI_IBS protocol initialized
[ 1.712688] Bluetooth: MSM Sleep Mode Driver Ver 1.1
[ 1.713184] [LG_BTUI] bluetooth_power_init : Called bluetooth_power_init
[ 1.713333] [LG_BTUI] bt_power_probe : Called bt_power_probe
[ 1.713598] [LG_BTUI] bluetooth_power_rfkill_probe : Called bluetooth_power_rfkill_probe
[ 1.751488] cpuidle: using governor ladder
[ 1.751673] cpuidle: using governor menu
[ 1.752037] mmc0: No card detect facilities available
[ 1.752333] mmc0: mmc power down
[ 1.752450] mmc0: Qualcomm MSM SDCC-core at 0x0000000012400000 irq 136,0 dma 18 dmacrcri 1
[ 1.752629] mmc0: 8 bit data mode enabled
[ 1.752724] mmc0: 4 bit data mode disabled
[ 1.752901] mmc0: polling status mode disabled
[ 1.752998] mmc0: MMC clock 400000 -> 48000000 Hz, PCLK 0 Hz
[ 1.753106] mmc0: Slot eject status = 0
[ 1.753282] mmc0: Power save feature enable = 1
[ 1.753382] mmc0: DM non-cached buffer at ff214000, dma_addr 0x60101000
[ 1.753568] mmc0: DM cmd busaddr 0x60101000, cmdptr busaddr 0x60101300
[ 1.753635] mmc0: mmc power up
[ 1.754171] mmc1: mmc power down
[ 1.754277] mmc1: Qualcomm MSM SDCC-core at 0x0000000012140000 irq 135,0 dma 19 dmacrcri 4
[ 1.754455] mmc1: 8 bit data mode enabled
[ 1.754551] mmc1: 4 bit data mode disabled
[ 1.754649] mmc1: polling status mode disabled
[ 1.754826] mmc1: MMC clock 400000 -> 48000000 Hz, PCLK 0 Hz
[ 1.754924] mmc1: Slot eject status = 0
[ 1.755102] mmc1: Power save feature enable = 1
[ 1.755199] mmc1: DM non-cached buffer at ff215000, dma_addr 0x60103000
[ 1.755378] mmc1: DM cmd busaddr 0x60103000, cmdptr busaddr 0x60103300
[ 1.755778] mmc2: mmc power down
[ 1.755884] mmc2: Qualcomm MSM SDCC-core at 0x0000000012180000 irq 134,642 dma 20 dmacrcri 2
[ 1.756065] mmc2: 8 bit data mode disabled
[ 1.756242] mmc2: 4 bit data mode enabled
[ 1.756338] mmc2: polling status mode disabled
[ 1.756435] mmc2: MMC clock 400000 -> 48000000 Hz, PCLK 0 Hz
[ 1.756610] mmc2: Slot eject status = 0
[ 1.756704] mmc2: Power save feature enable = 1
[ 1.756880] mmc2: DM non-cached buffer at ff216000, dma_addr 0x60104000
[ 1.756977] mmc2: DM cmd busaddr 0x60104000, cmdptr busaddr 0x60104300
[ 1.757259] bcm432x_sdcc_wlan_slot_status: 34 0
[ 1.757581] mmc3: mmc power down
[ 1.757686] mmc3: Qualcomm MSM SDCC-core at 0x00000000121c0000 irq 133,290 dma 21 dmacrcri 5
[ 1.757862] mmc3: 8 bit data mode disabled
[ 1.757957] mmc3: 4 bit data mode enabled
[ 1.758131] mmc3: polling status mode disabled
[ 1.758229] mmc3: MMC clock 400000 -> 48000000 Hz, PCLK 0 Hz
[ 1.758407] mmc3: Slot eject status = 1
[ 1.758503] mmc3: Power save feature enable = 1
[ 1.758602] mmc3: DM non-cached buffer at ff217000, dma_addr 0x60106000
[ 1.758781] mmc3: DM cmd busaddr 0x60106000, cmdptr busaddr 0x60106300
[ 1.759238] mmc4: mmc power down
[ 1.759345] mmc4: Qualcomm MSM SDCC-core at 0x0000000012200000 irq 220,0 dma 21 dmacrcri 14
[ 1.759525] mmc4: 8 bit data mode disabled
[ 1.759620] mmc4: 4 bit data mode enabled
[ 1.759715] mmc4: polling status mode disabled
[ 1.759890] mmc4: MMC clock 400000 -> 48000000 Hz, PCLK 0 Hz
[ 1.759985] mmc4: Slot eject status = 0
[ 1.760161] mmc4: Power save feature enable = 1
[ 1.760256] mmc4: DM non-cached buffer at ff218000, dma_addr 0x60107000
[ 1.760430] mmc4: DM cmd busaddr 0x60107000, cmdptr busaddr 0x60107300
[ 1.760993] Registered led device: button-backlight
[ 1.761718] usbcore: registered new interface driver usbhid
[ 1.761818] usbhid: USB HID core driver
[ 1.762469] logger: created 64K log 'log_main'
[ 1.762791] logger: created 256K log 'log_events'
[ 1.763024] logger: created 64K log 'log_radio'
[ 1.763330] logger: created 64K log 'log_system'
[ 1.764004] usbcore: registered new interface driver snd-usb-audio
[ 1.764408] No device for DAI CODEC_DAI
[ 1.764504] No device for DAI CPU_DAI
[ 1.764888] msm_soc: create pcms
[ 1.765091] asoc: CODEC_DAI <-> CPU_DAI mapping ok
[ 1.766098] No device for DAI MVS_CODEC_DAI
[ 1.766199] No device for DAI MVS_CPU_DAI
[ 1.766735] asoc: MVS_CODEC_DAI <-> MVS_CPU_DAI mapping ok
[ 1.768013] ALSA device list:
[ 1.768116] #0: msm-audio (MSM-CARD)
[ 1.768292] #1: msm-voip (MSM-MVS-CARD)
[ 1.768451] u32 classifier
[ 1.768547] Actions configured
[ 1.768728] Netfilter messages via NETLINK v0.30.
[ 1.768876] nf_conntrack version 0.5.0 (12878 buckets, 51512 max)
[ 1.769283] ctnetlink v0.93: registering with nfnetlink.
[ 1.769453] xt_time: kernel timezone is -0000
[ 1.769702] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 1.770012] arp_tables: (C) 2002 David S. Miller
[ 1.770149] TCP cubic registered
[ 1.770386] NET: Registered protocol family 10
[ 1.770888] lo: Disabled Privacy Extensions
[ 1.772921] Mobile IPv6
[ 1.773056] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 1.773244] IPv6 over IPv4 tunneling driver
[ 1.773724] sit0: Disabled Privacy Extensions
[ 1.774004] NET: Registered protocol family 17
[ 1.774308] Bluetooth: L2CAP ver 2.15
[ 1.774406] Bluetooth: L2CAP socket layer initialized
[ 1.774593] Bluetooth: SCO (Voice Link) ver 0.6
[ 1.774688] Bluetooth: SCO socket layer initialized
[ 1.774931] Bluetooth: RFCOMM TTY layer initialized
[ 1.775038] Bluetooth: RFCOMM socket layer initialized
[ 1.775217] Bluetooth: RFCOMM ver 1.11
[ 1.775313] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.775410] Bluetooth: BNEP filters: protocol multicast
[ 1.775588] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.793709] set_dload_mode : 0
[ 1.797879] init_watchdog regsave = -537493504
[ 1.797993] MSM Watchdog Initialized
[ 1.798421] VFP support v0.3: implementor 51 architecture 64 part 2d variant 0 rev 0
[ 1.800551] pm8058-rtc pm8058-rtc: setting system clock to 1970-01-01 02:26:48 UTC (8808)
[ 1.800739] ############ [msm_charger_temperature_battery_alarm] #####################
[ 1.801733] ############ [msm_charger_temp_work] POLL TIME = 5400 #####################
[ 1.804059] pm8058_is_battery_present: therm_raw is 1112
[ 1.804239] batt_read_adc: couldnt open channel 0 ret=-9
[ 1.804338] pm8058_is_battery_id_valid: batt_id_mv is -22
[ 1.806815] pm8058_is_battery_temp_within_range: therm_celcius is 27
[ 1.808070] max17040_get_mvolts: Battery voltage is 3580
[ 1.808767] max17040_get_capacity_percent: Battery SOC is 9
[ 1.811174] batt_read_adc: couldnt open channel 0 ret=-9
[ 1.811350] pm8058_is_battery_id_valid: batt_id_mv is -22
[ 1.813747] pm8058_get_battery_temperature_adc: therm_raw is 1112
[ 1.814096] determine_initial_batt_status:OK batt_status=2
[ 1.819402] pm8058-charger pm8058-charger: pm8058_chg_determine_initial_state charger absent
[ 1.819587] pm8058_batt_alarm_state_set: BATTERY ALARM SET DISABLE
[ 1.824752] pm8058_batt_alarm_threshold_set: pm8058_batt_alarm_threshold_set : lower_threshold_mV = 4120, upper_threshold_mV = 4200
[ 1.825104] pm8058_charger_probe: pm8058_charger_probe OK
[ 1.825359] HSD.fsa8008[lge_hsd_init : 768]lge_hsd_init
[ 1.825658] HSD.fsa8008[lge_hsd_probe : 525]lge_hsd_probe
[ 1.825998] HSD.fsa8008[lge_hsd_probe : 608]hi->irq_detect = 639
[ 1.826344] HSD.fsa8008[lge_hsd_probe : 633]hi->irq_key = 640
[ 1.826685] input: ffa-keypad as /devices/virtual/input/input12
[ 1.827259] LGE: Android Vibrator Driver Init
[ 1.833434] max17040_get_mvolts: Battery voltage is 3580
[ 1.833634] [LGE:vibrator] GPIO_LIN_MOTOR_EN gpio value :0
[ 1.838920] LGE: Android Vibrator Initialization was done
[ 1.849544] max17040_get_capacity_percent: Battery SOC is 9
[ 1.850277] msm_otg_suspend: usb in low power mode
[ 1.860272] batt_read_adc: couldnt open channel 0 ret=-9
[ 1.860451] pm8058_is_battery_id_valid: batt_id_mv is -22
[ 1.876366] pm8058_get_battery_temperature_adc: therm_raw is 1112
[ 1.877764] Warning: unable to open an initial console.
[ 1.907777] mmc0: new high speed MMC card at address 0001
[ 1.908242] mmcblk0: mmc0:0001 HYNIX 7.22 GiB
[ 1.908597] mmcblk0: p1 p2 p3 p4 < p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19
[ 1.913986] max17040_get_mvolts: Battery voltage is 3580
[ 1.914229] p20 p21 p22 p23 p24 p25 p26 p27
[ 1.915138] max17040_get_capacity_percent: Battery SOC is 9
[ 1.915662] p28 p29 p30 p31 >
[ 1.918338] batt_read_adc: couldnt open channel 0 ret=-9
[ 1.918522] pm8058_is_battery_id_valid: batt_id_mv is -22
[ 1.919183] mmc1: mmc power up
[ 1.921569] pm8058_get_battery_temperature_adc: therm_raw is 1112
[ 2.049205] mmc1: mmc power down
[ 2.051085] mmc2: mmc power up
[ 2.144947] init: cannot open '/initlogo.rle'
[ 2.146148] init: Unable to open persistent property directory /data/property errno: 2
[ 2.178595] mmc2: host does not support reading read-only switch. assuming write-enable.
[ 2.178793] mmc2: new high speed SDHC card at address b368
[ 2.179216] mmcblk1: mmc2:b368 SD 3.75 GiB
[ 2.179575] mmcblk1: p1
[ 2.181386] mmc3: mmc power up
[ 2.191544] mdp4_overlay_pipe_alloc: pipe=c0a5e820 ndx=1 num=0 share=0 cnt=0
[ 2.191728] mdp4_overlay_writeback_setup: base=423d1800 offset=859800
[ 2.234607] mmc3: mmc power down
[ 2.234808] mmc4: mmc power up
[ 2.302243] mipi_dsi_host_init: mipi_dsi_sw_reset ..
[ 2.302344] mipi_lgd_lcd_on: mipi lgd lcd on started
[ 2.368031] mmc4: mmc power down
[ 2.530299] mdp_disable_irq_nosync: MDP IRQ term-0x20 is NOT set, mask=1 irq=1
[ 3.045291] EXT4-fs (mmcblk0p27): recovery complete
[ 3.049505] EXT4-fs (mmcblk0p27): mounted filesystem with ordered data mode. Opts:
[ 5.888629] daniel.kang volume-dn : MHL_OFF
[ 6.262474] daniel.kang volume-dn : MHL_OFF
[ 6.787392] daniel.kang volume-dn : MHL_OFF
[ 7.162937] daniel.kang volume-dn : MHL_OFF
[ 7.496486] daniel.kang volume-dn : MHL_OFF
[ 7.867941] daniel.kang volume-dn : MHL_OFF
[ 9.198563] Power Key Pressed!Power Key Release!
[ 11.520651] daniel.kang volume-up : MHL_ON
[ 12.201534]
[ 12.201538] (IOS backup)
[ 12.201541] mmc2: clock 48000000Hz busmode 2 powermode 2 cs 0 Vdd 15 width 2 timing 2
[ 12.202849] mmc2: mmc power down
[ 12.241506] msmsdcc_runtime_suspend() - host->mmc->index=3 - Start
[ 12.241608] local_clk_disable_nolock: Reference counts are incorrect for clock 30!
[ 12.241880] local_clk_disable_nolock: Reference counts are incorrect for clock 73!
[ 12.242059] msmsdcc_runtime_suspend() - host->mmc->index=3 - EndPower Key Pressed!Power Key Release!
[ 15.195271] daniel.kang volume-up : MHL_ON
[ 18.251489] daniel.kang volume-dn : MHL_OFF
[ 23.569426] mmc0: mmc power down
[ 31.570385] Power Key Pressed!mmc0: mmc power up
[ 31.762359] Power Key Release!
[ 31.812523] SysRq : Emergency Remount R/O
[ 31.813197] sys_reboot: sys_reboot is called from android
[ 31.813327] sys_reboot: reboot cmd is 19088743
[ 31.813434] lge_set_kernel_shutdown_nofityed, state : 4
[ 31.814343] k3dh_shutdown !
[ 31.814590] sensor_common_power_set pwr_mask(2), on(0), sensor(1)
[ 31.814875] lm3537_shutdown
[ 31.818993] Initiating msm_sdio_al_shutdown...
[ 31.819093] msm_sdio_al_shutdown complete.
[ 31.819368] charm_modem_shutdown: AP2MDM_PMIC_RESET_N goes low!!
[ 31.827519] EXT4-fs (mmcblk0p27): re-mounted. Opts: (null)
[ 31.828419] Emergency Remount complete
[ 36.211711] Restarting system.
[ 36.212205] set_dload_mode : 0
[ 36.213037] set_dload_mode : 0
[ 36.213484] Going down for restart now : (null)
No errors detected
