Root eMiui 2.8.3 (unofficial miuiandroid)
Status
Not open for further replies.
LowEndGeek
Android Expert
[MOD NOTE]
Thread closed at request of OP - this ROM is no longer supported.
[/MOD NOTE]
All new Emiui unofficial MiuiAndroid 2.8.3
More screenshots
Credits
# Xiaomi [MIUI]
# Phenomx4 [CM9 and pointing me in the direction of the roaming indicator fix]
# Artine [Inspiration from Hydra]
# Lens_flare [Porting Guide]
# Everyone [For everything]
Installation Instructions
** Always make a back up first
1. Do a full wipe
** Full wipe includes data/reset factory resotre in recovery, wipe cache, under mounts and storage wipe system, under advanced wipe dalvik
2. Flash the ROM
3. Flash gapps
4. Reboot (this might take some time due to app optimization)
5. Wait few minutes and reboot again
6. Enjoy MIUI and ICS
September 12 2013
Updated apps:
Calendar
Calculator
Email
Autostart Manager
Super Market
Sound Recorder
Updated system theme.
Music
Other Things:
added partial v6 and ram tweaks to hopefully help with miui's insane ram usage
Added custom hostfile
issues
Only the internal storage gets mounted for some reason. Might need some help with that
Anything else let me know.
Downloads
Virgin Mediafire
md5 f6da778cd5d806cdf76dde74031d0b34
Miui gapps (slightly changed, took out gallery mostly)
I made some progress with cMIUI and I feel like I should put it into it's own thread.
Ok first things first, always be sure you know what you are doing before flashing this rom, I am not responsible if your phone spontaniously combusts.
Basic install goes like this:
1. Do a full wipe (recommended but not always necessary)
2. Go to recovery and flash the ROM
3. Reboot (this might take some time due to app optimization)
4. Wait few minutes and reboot again
5. Enjoy MIUI and ICS
Credits
# Xiaomi [MIUI]
# chillzz81 [cMIUI SGS2]
# Phenomx4 [CM9]
What Works
# Everything that works on cm9 as of 5/7/2013
# Miui Themes
# Miui Security Tools
# Miui Compass
# Miui Sound Recorder
# All Miui Tools seem to work just fine
What Doesn't Work
# Anything that doesn't work on cm9
# Update me app was created for the galaxy s2 and it wont work for our device and will be removed in the next release, for now either remove with titanium or just ignore it.
Bugs and Quirks
# Status bar shows "roaming indicator off" i'll fix this shortly
##to work around the roaming indicator open up ics control and go to carrier options and either turn off or change it to a custom one.
# Status bar shows both 1x and 3g status bars, again i'll fix this shortly
# The lights stay on on the phone buttons (home, menu, search, back) even when screen is shut off
# Keyboard is slightly cut off at the bottom (just install a new keyboard for now and i'll fix it soon)
# Please let me know asap anything else you find.
# Gallery is a little wonky, let me know how it works for you.
Downloads:
Virgin Mobile Devhost
MD5 Sum: 07703aa394ea7c24c19dbfaaad5c91a8
Gapps are included in the rom already (probably going to change shortly)
Sprint fans I apologize i'll get you tomorrow along with screenshots (library is about to close)
I hope everyone enjoys
Flashing now, will keep you posted....Thanks for all your work
Yea rom won't let me do anything not even simple text or phone call...all does force close n freezes saying android process has stop repeatedly it acts like dead rom ....
Boot into recovery, Wipe Data, cache, Dalvik, Re -flash the rom also fix permissions after you re-flash under advanced & it should take care of those force closes, !!
Also, make sure you don't restore data from a nandroid from another ROM. That can cause all kinds of problems.
So i can't restore my data from cm9 alpha to this
Rom? I don't understand why this rom base off one we using now....
I Restore data fine with miui just keeps getting stuck
On stupid n freezes n force close won't even open
Up a single app or text or nothing.... I don't think it data problem
kuz if it was Im pretty sure ken would said something in
Description on top...
I "never" restore my data & it's just there because it's backed up in Google account, as soon as I set up my google account "there's my data right back!!!
Doesn't it re download all apps for you once back up on Google ? Or will I have download them myself again
And it will restore data?
In the OP says "data fixed" is that fixed at the CM9 source or just for the MIUI rom?
Miui. I got phenoms source about 5 min before my wifi shut off so I haven't been able to look at it yet.
Spaz I'm sorry you are having such problems. It doesn't seem like anyone else is having. Did you verify the md5 perhaps it was a bad download.
Also I just discovered mms doesn't work
Hello Ken I am having basically the same problem spaz1418 is having. a lot of things just force quite the app "phone" being one example with a "Unfortunately, the process andriod. process.acore has stopped working". I also have a black background and cannot change it and the status bar is not even there. the locker screen background is not black it has the little leaf background . I wiped Dalvik and cache and even tried cfreeman90 idea on fix permission. I however did not wipe for data. Should I try that? spaz said he did and it did nothing so i do not want to waste time on that. By the way ken I love the default launcher did you make it?
Status
