This is basically piracy buddy. You should remove the link.
I did.... now remove yours that you quoted.
It has been addressed, in fact you could read about 5 posts before yours!!Personally I could care less about the bars and my theory is its showing the EVDO (or 3g) strength, actually I like it better because if your phone has 3g on it you'll have voice....vzw typically does data on the pcs band so its going to be "weaker" than their cellular voice band. This is only my theory...and I've been drinking...but i tested it I swear! Read a few posts previous for the fix, I'll make you read my diatribe but ya gotta look for your answer
Handcent and Chomp are simply "front ends" to the built-in "Messaging" application. I don't think that issues like sending (or receiving) are the fault of 3rd-party SMS apps. In fact, I've had failed deliveries when using the built-in SMS app. Well, let me rephrase that: It says it failed but the message does actually go through.
HMM maybe theres a glitch with my phone. I can tap actual button all day long. Worked with 1.5. Also went back to spare parts and set end call behavior to sleep and still nothing? Has anyone else had this problem?Pressing the physical "end call" button will put it to sleep.
E36?
Agreed.
Handcent shouldn't be handling the sending/receiving, at all.
Go into Handcent settings, and make sure that handcent itself is NOT set to automatically download messages, or do anything related to sending or connecting to any messaging service.
It's not supposed to try.
Messages is. If you can send a message in Messages, I promise, you can use Handcent.
My gf, on Cricket no less, is using Handcent on her (poor version of) 2.1.
Should work without a problem.
Actually I had alot of problems with Handcent on 2.1 as well as a few other people....
I switched to Chomp....not having those problems anymore, not sure why as I always used Handcent before
Mine shows me ALL messages. I didn't change anything.
Here is a pretty significant bug/issue. The HTC People widget no longer works. It crashes Sense every time it tries to load it.
Any one having issues with handcent when try to type "I'M" it freezes my phone and I have to turn it off and back on... Any help on this would be great...
Nope. I would go to my contacts in gmail though before doing the update, just to make sure.If all my contacts are synced though Google and none from the phone will I have to back up my contacts before doing the update?
I think someone woke up on the wrong side of the bed...
I'm pretty on top of this forum and am a little confused as well... Is the "other" leak the one Caddy posted? Or is there another?
Alright, lately I'm having a hard time finding relevant information on this board.
I've now had 2.1 since it first dropped. I love how fast my phone is, ect. I'm pretty much just ignoring the fact that my facebook will not sync with my contacts, but it's something I'd like eventually. I figured the OTA was coming soon, but apparently it's farer off than we'd like.
Has anyone figured out how to get the contacts to sync? Do i really have to reset my phone again? The only reason I don't want to is I don't want to re-do all my anycut shortcuts
thanks guys, sorry if i missed this answer
