Also, a quick note, I just tried Ginger Tazz 7, and that didnt work either, the message on my phone said it couldnt even unpack the zip file with the message "(bad)" underneath the name.
THANKS!!!
beamer,
Welcome to Android Forums!
By the way, even though Amon_RA's custom recovery won't allow a "bad" .zip (ROM or otherwise) to be flashed because it does a signature check, you can save yourself some grief (and time) by double-checking that the file (ROM or otherwise
) was downloaded and transferred to your phone completely and without corruption. If you are using ClockworkMod
eek
, you apparently have to enable signature checking since its not on by default (consensus is that this is a "bad thing").
Verifying the completeness and validity of a file is typically done by
1) verifying the checksum (usually MD5) of the file
and/or
2) doing a 'jarsigner -verify' type check on the signed .zip file.
You should check and compare the MD5 sum from the publisher (ROM developer) of the file
after you have placed it on your phone (since that's the "last mile"). A diligent and thoughtful ROM developer will have the checksums of his/her downloads published (if they don't--stay away from that ROM!).
File manager utilities like Astro File Manage will show you a file's MD5 checksum (long-press the filename, select Details, and if the file is especially large (like a ROM), it might take a minute or two for the MD5 checksum to be displayed). You can also use my app,
AFV (Android File Verifier) [free in the Market, btw], to calculate both the MD5 checksum (others too) and do a "Jar Verify" (verify a signed .zip file).
Cheers!
