android market on rom ld lg 3.5 downloading app an error 498 shows up every time
Hey guys i need some help when i try rooting my esteem nothing happens...
i clicked on run.bat it starts daemon successfully but it just remains saying it.
i let it sit there for several minutes but still nothing i restarted my phone and computer and even ran the bat file as administrator still no success. Any help?
Hey guys, i have searched for a solution to this problem for months now and no answer, my phone wont connect to any pc thru USB, i have installed the drivers several times, i wont even get a notification on the phone, when i connect it to the pc i get a fail connection sound, most times the pc wont even give me a notification for software install (or lack of) but when it does it always says that the device can not be installed, the phone charges fine both from the pc or wall adapter, please, i need some help from the gurus, i've searched and searched and all the advice i find its "make sure u enable it on the notification bar" or "use the LG USB wire only" and stuff like that, non of which has worked for me, very many thanks in advance guys
my esteem keeps restarting after i put the number 2 rom
My phones mic or headset will not work in call. I have to put the phone on speaker to hear and be heard. I'm running the latest #2 with plagued kernel. I have tried multiple times with a fresh install but can not get it to work correctly..
flash black plauge rom to rule it out and come to find out it thinks headphones are plugged in. never could tell with #2 since the icon does not appear in the notification bar. but with black plauge i can clearly see my phone thinks headphones are plugged in. it jumps on and off at will and at random times. there is no method to its madness..
Help please
Help please
Which thread are you referring to. I searched this forum and didn't find anything.Gturn read the cwm touch thread. It will help you.
Back to my problem, found out it is showing the headphone problem when my phone gets hot.. Someone help, is there an app to just disable the headphones. Or can someone explain if I can just edit my phones files to think I have no headset jack?
http://androidforums.com/esteem-all-things-root/598387-mod-cwm-touch-6-0-1-1-install.html
that should help you out....
wish someone could help with my problem, my next action is going to be trying to swap out the headphone jack with another one i have from an esteem with no uicc card.
