TEST MODE FIX
--Plug your phone into your USB connection.
--Go to
START then
CONTROL PANEL then
DEVICE MANAGER. Scroll down to
"Ports(Com and LPT)" Expand it and your phone SHOULD be listed with a "COM7", "COM3" etc....
--Get YOUR "COM" number and remember it. This is what USB port you are plugged into. (If you don't see your phone, the drivers are NOT installed correctly.)
--Open and extract the Test Mode Zip on your desktop
--Open up the folder "Test Mode Fix" You should be looking at this.
--Open the drop down menu and find YOUR "COM" port.
--Click on CONNECT after you select YOUR "COM" and it SHOULD look like this.
--It takes 2-3 seconds and your phone will reboot if it is successful.
CONGRATULATIONS. You are now out of the dreaded TEST MODE.
Now for the fun stuff. Let's get your service back working.
SO I FOUND THIS THREAD IN THE FORUM AND THOUGHT IT WAS THE ANSWER TO ALL MY PRAYERS. I HAVE READ THIS THREAD ABOUT 5 MILLION TIMES THOROUGHLY AND READ ALL THE COMMENTS AND REPLIES...WELL MOST OF THEM. I DIDN'T WANT TO BE THE ONE TO ASK A RIDICULOUS QUESTION AND THE ANSWER IS RIGHT IN FRONT OF MY FACE SO I CONTINUED TO READ IT OVER AND OVER TO LEARN ALL POSSIBLE ERRORS THAT COULD ARISE AND SOLUTIONS TO THOSE ERRORS.
YES, I HAVE ALL THE SYMPTOMS OF TEST MODE {{CAN'T MAKE/RECEIVE CALLS/TEXTS, 4G ENABLED, NETWORK SAYS SEARCHING FOR SERVICE, NO PHONE #, MIN #, OR PRL VERSION#, NOT ROAMING, ROOTED LG ESTEEM, JUST FACTORY RESET ABOUT 2DAYS AGO -- HAD NO CHOICE
-- I WAS STUCK IN RECOVERY MODE LOOP FOR A WHOLE DAY TIL I FOUND THE EXITRECOVERY.ZIP (FORGOT WHO DEVELOPED IT BUT THANK YOU), HIT "#" AND HIDDEN MENU COMES UP, USB SAYS FACTORY CABLE MODE, ETC..ETC.}} I GOT EVERYTHING DOWNLOADED, INSTALLED, UNZIPPED, & REGISTERED, FOLLOWED ALL THE STEPS AND WHEN I GET TO THE TEST MODE FIX IT SAYS THIS
"Connecting to COM3...
Reading Device Please Wait...
Connected To: LG Esteem (MS-910)
Device Fail To Unlock!
Reboot device and try again!
Device Software: Feb 24 201218:10:52Feb 24 201218:10:52MS910ZVD
Device Build: M7630A-ABBQMA
Device MEID: *************
Attempting to repair test mode!
Test mode disabled failed!
Restarting Device!
Please Try Again!"
DEVICE FAIL TO UNLOCK IS IN "RED" AND TEST MODE DISABLED FAILED IS IN "RED" AS WELL. MY PHONE NEVER REBOOTS AND I HAVE TRIED EVERY USB PORT ON MY CPU...........SO WHAT AM I DOING WRONG? HELP!
