gbiggie
La patience et le pardon
DISCLAIMER: I AM NOT RESPONSIBLE FOR ANYTHING YOU DO TO YOUR COMPUTER OR LG ESTEEM IF YOU CHOOSE TO DOWNLOAD THESE FILES
This is exactly what it says it is:An un-rooted stock system pull of versions B-C-D of the MS910 Esteem.
What can you do with them:Use them as a base to learn to build ROMS,kernels,themes, or just explore them as I have been.
These are not flash-able zip files to use in recovery with your phone(It has been explored but only D was tested and does not work). If you choose to try it do not ask for a solution to fix your phone if you brick it.
This might generate too much traffic for Dropbox as it did with the downgrade files if it does they will suspend my account for 3 days. Just an FYI.
Please download this to your phone and keep a copy on your external SD-It is a lifesaver to get your phone working again quickly
http://dl.dropbox.com/u/64026439/exitrecovery.zip
ZVB-http://dl.dropbox.com/u/64026439/Stock Pulls/MS910ZVB Esteem.zip
MD5-e92dfd009443b9d210ea6f3952c1f08d
ZVC-http://dl.dropbox.com/u/64026439/Stock Pulls/MS910ZVC Esteem.zip
MD5-dd01e1c1c46f66a564780123af3d0830
ZVD-http://dl.dropbox.com/u/64026439/Stock Pulls/MS910ZVD Esteem.zip
MD5-d1c90d5065ff15b44e5ff560a402ae64
Apply common sense please:vroam:
