not exactly sure what features you are asking about. cm7 is an aosp rom and that it does not have sense. so that usually makes the rom a bit faster and smoother. it takes a little more tweaking then sense, but overall i really like cm7. if you couple that with the tiamat kernel, i was getting the best battery life. i do miss that rom/kernel combo because of the battery life. but, these new sense 2.1 and 3.0 roms are very cool. i might come back to cm7 at some point.
yep virus's kingdom rom is pure sense 3.0. you can get it on the rom/kernel sticky. you have to partition your sd card as it is a beast in size and you will not have room for your apps. here is a guide that i used:[GUIDE][07/07/11]How to Partition your SD Card - xda-developers. it is recommended that you have a class 4 or higher card though for better performance.
