When I plug my evo into my computer, Vista says "unknown device found". With that, I can't do anything. The main reason I want to connect it is for the app DoubleTwist. But without my computer recognizing it, I can't do anything. Oh. I'm new.. Help please?
You need to make sure that when you hook your phone up the phone is set to be read as a disk drive and is not on the other options. If you are unsure with the phone connected to the computer drag down the notification bar and you should see a usb icon it will tell you how its hooked up
1 is Charge Only
2 is HTC Sync
3 is Disk Drive
4 is USB tethering
Make sure disk drive is the selected option.
