Root EVO ONLY boots to HBOOT! HELP!!
NichoRyan
So I have the EVO 4G rooted with Unrevoked running Cyanogen7. The phone had been working flawlessly for a few months but suddenly the volume down button started sticking. It wasn't too bad - it would just turn the volume down by itself and hold down until I pushed the volume up button. It went away, and a couple days later, I turned my phone off - BAD move.
Now whenever I try to turn my phone on, its stuck in the HBOOT menu. Sometimes the 4/5 times I try to turn my phone on, it starts up in HBOOT and the volume buttons won't work to scroll. 1/5 times, the volume buttons DO work.
I've tried wiping, restoring, re-flashing, resetting, and EVERYTHING else I can think of but NOTHING WORKS! It always starts up in HBOOT! =[
ANYYYYY HELP WOULD BE GREATLY APPRECIATED!
Thanks!
Sounds more like a Hardware issue than a software one. You could try electronics cleaner that would be a help. Try spraying the volume controls. May even need to take the back off the phone a spray around the buttons and where the connectors are for them.
Thanks for the reply!
I thought the same thing too... But even after cleaning it, it did the same thing. And the fact that it boots to HBOOT even when the buttons DO work lead me to believe its not the hardware....
Maybe a bad HBoot. Could be ROM but it seems to me that its the HBoot. Next time you are successful getting into the ROM maybe click back the fast boot option. I would try to reflash the HBOOT Would be better if you could do a nandroid backup.
what recovery do you have? i would try to wipe dalvik cache and cache and re-flash your rom. if that does not work then try and do a full wipe and use superwipe and then flash a rom.
My recovery build is: RA-supersonic-v2.3
But here is the kicker:
I left my phone alone untouched all night. This morning, I decided I'd give it one more try before I completely give up. I put my battery in, pushed the power button, and it turned ON!!! I let my phone sit for a while as I reveled in its new life. I then checked the missed voicemails and texts that have built up in the past three days. I didn't know who they were from because my SD card was formatted and my contacts were deleted. Then my stupid self goes to take out the battery so I can throw my contacts and pictures back on my SD card. When I go to turn the phone on again, it goes back to HBOOT.
WTF!?!?!?
Maybe it is a hardware problem?
what is your hboot? it does sound kind of odd. the good thing is that we can unroot you and maybe that might fix the problem. and if unrooting does not fix it then you should be good to go in taking it in to sprint.
So I tried un-rooting using the unrevoked-forever-son.zip (Official RUU return to stock and S-ON for HTC Evo 4G)
Then I got:
E:unsupported radio version
E:Update failed. Check /sdcard/soff.log.
E.Error in /sdcard/unrevoked-forever-son.zip
(status 42)
Apparently I can't unroot my phone because its software is up to date and the .zip isn't able to make it s-on....
Now what?
you can't use unrevoked s-on because of how you originally rooted with revolutionary and because of your hboot.
go to the http://androidforums.com/evo-4g-all...ooting-dummies-guide-gingerbread-edition.html and go to the unrooting section.
this really sounds like a sticky down volume issue. as in its sticking and leaving it sit overnight slowely the down volume was able to unstick.
ok now that is unusual. try and re-download of the file and try again. also what size card do you have? if it is a 2g card, then your evo may not like the card. i have seen that 2g cards just do not work well when trying to flash or install things from it.
Sorry this thing has been so frustrating for you. Ocn is one of the best to be on your case. I mean Seriously if I get in trouble he's the first one I'm calling.
I think at this point first thing I would do is take out the SD card and ensure it has nothing wrong with it. I would put it in card reader in windows and run a checkdisk command
Start > Run and type cmd
in Dos Box type:
chkdsk x: /f /r
replace x with the drive letter of your SD Card. If everthing is a go there you may want to try to redownload the ruu maybe it got corrupt during the download. then try it again.
I still think its a hardware issue though. IF we can get you unrooted take it back to sprint and let them exchange it. (Do you have insurance on the phone?)
ZOMGGGZZZ!
I finally got S-ON!!!!
Holy eff bomb!!!
I'm definitely sure there's a hardware problem now (in addition to a potential software problem)...
As I was trying multiple sizes, brands, and classes of SD cards, I finally just kept jamming the Volume Up button while it was parsing just in case it finally went through.... And eventually it did! Now when I turn my phone 'on' it goes to the HBOOT screen and reads,
SUPERSONIC EVT2-3 SHIP S-ON
HBOOT-2.16.0001
MICROP-041f
TOUCH PANEL-ATMELC03_16ac
RADIO-2.15.00.05.02
Is it fine to take back to Sprint now?
ZOMGGGZZZ!
Holy eff bomb!!!
HBOOT-2.16.0001
MICROP-041f
RADIO-2.15.00.05.02
As Ocn said make sure you have the stock ROM and Recovery on it.
