Root Evo Port Test ROMs | Droid Incredible
Then what is soooo different about the CyanogenMod 6 Test 8 which allows use of the Wiimote Controller? I understand it's the Bluetooth stack...
But why doesn't everyone include that Bluetooth stack into their ROMs then?
Its not something that is being left out.
What rom does it work on, and what files control it, specifically?
is the dl link not working for anyone else? it brings me for the site to download it and then when i click download, it says the file is missing?
adrynalyne are you going to release a vanilla version for this rom?
edit: nvm i finally got mine working, it didn't like launcher pro in the data/app folder, setup.apk was force closing. moving it to system/app did the trick. This is a really nice rom senseless, good job man.
just curious... with this rom the signal I'm getting is about -82 db and it's showing 5/6 bars.
with other roms my db is around the same but I get 1 bar
which is right?
Hadn't really thought about it. I'm already juggling three roms ;)
it's ok mine is working now, i know your doing alot, i created a really slim sense rom from this and a senseless one, i can upload it tonight to you if you want to check it out and release it.
Edit: i've been following you since the omnia days.
Can we get the hide location zip to work with this please? It will install and remove the location icon, but it also removes the sweet 6 signal bars and puts them back to the ugly 4 bars. Anybody have a fix for this?
i looked into that yesterday, it doesn't work because the services.jar are different between the inc and evo, i too would like to see someone with more skills than i to edit the services.jar for the evo framework.
adrynalyne maybe you could put this into your next beta update? or figure out a way to keep the 6 signal bars and remove the location icon since I'm sure you're more familiar with the evo framework than anyone else here. Maybe even just a zip we could install on top of any of the Evo betas?
And maybe add tv out?
I can try---it requires framework hacking and while I can decompile it fine...Im having trouble locating where that hack needs to be done at.
