DMedina559
Hi all..
Not sure if this is the correct thread, but it is related. I got root access and root check with giantpune's poot method. It worked flawlessly. Now I want to do the back up w/CWM so I can uninstall all the stock bloatware.
My questions are: Do I have to use an external device for the nandroid backup? I've read that I do, and in other places that I don't. I'm confused. If so, can I use an external sd card? I'd rather just do everything on/from the phone if I can, but I'll buy and external sd card if I have to.
My PC is a dinosaur and probably doesn't have the memory, and my other one is an old imac, on which android apps won't work with.
If this is the wrong thread for this question, I apologize. Thanks in advance! You guys are great!
You could use the internal or external SD for just about everything in CWM5/6
This thread is still actively maintained on a regular basis when new updates are available - CyanogenMod 9 was recently added to the list of available ROMs as well. Also, CM7 and CM10 are being worked on. CM10 hasn't had as much development, IIRC, mostly because developing CM9 for the OE and then upgrading that to CM10 is easier than just doing CM10 from scratch.
