when I type busybox in terminal emulator it says not found.
Install it from the market.
already had it installed.
Have you checked if busybox is located in /system/xbin or /system/bin?
Does busybox have the correct permissions set? should be (rwsr-xr-x)
so if i would return it would they ever be able to tell it had been rooted?
I am so glad Pune got it going. You helped me root the sprint version before anyone else, so I hope by doing that, it gave you the info you needed to get everything working. I am going to install cwm tonight and see what damage I can do, lol, or not do. Has anyone tried any of the roms yet? Any worth while?
get my MSL number with any of the methods decribed. I tried the aLogcat method, the win7 method, I even resorted to calling Sprint, and they A-Holes
wouldnt come up off of it. I even lied and told them I was a dev and needed it, then tried the ol' need to reset my phone trick, of course that didnt work.... so... if anyone can helpme out here I would appreciate it!!
NopeIs it even needed to install CWM?
OK, Im stuck already. I can notget my MSL number with any of the methods decribed. I tried the aLogcat method, the win7 method, I even resorted to calling Sprint, and they A-Holes
WASSUP HASHTAG########!!!!:stupido:
Are you sure you're typing the path correctly?File not found.? Renamed. I put it in both cards, internal and external. What's wrong?
I flashed the recovery then manually booted into it. It CWM flashed so I rebooted out so out to download harmona. Booted back in later and now it's back to the stock recovery. Did I do something wrong?
Its about my 5th time flashing the recovery - all steps thoroughly taken from stock OE elite- root done through poot/ministroII. Currently running Harmonia 2.03 - changing immedietly to anything else. probably tagged - F**k google wallet.
anyway upon flashing CWM check sum matched**
I boot in and have no access to sdcard yet there is a special entry (install from "internal" sdcard at the bottom - rather then using install from sdcard..
well the main issue is making backups / restore > I try and it says cant mount sdcard - as well as trying the first entry " same response "
but the last entry "install from INTERNAL sdcard" allows me to install roms = backing up still an issue ..
Ill flash again but i feel that i may be using a microwave soon to flash this.
After installing CWM, but before powering off/rebooting, you need to either rename or delete the following file:
/system/etc/install-recovery.sh
So, rename it to install-recovery.sh.bak or just delete it. If you don't, the stock recovery will be restored on the next boot.
