Root Fastest way to change fonts?
evomattnc
Android Expert
Ok so I was running vaelpak 3.2 which was great. He had an app on it called font changer and you opened it and it showed examples of like 10 different fonts and you just picked one and bam new font. Well I grabbed destroyer for cm 7 and obviously don't have that application anymore. I tried to load it using root explorer and that was a fail, just fcs. So is there an app that will work or a faster way to load these font packs I have dled? I know I can push with adb or terminal emulator but typing the commands out is just as long as flashing. Just hoping for a lazy one click way like on vaelpak.
Never mind found a font changer app in market. Had to extract the zips and pull out the .ttfs and move them and rename them but only have to once I can change fonts on all my roms now.
