Sorry was just so happy I finally took the plunge. I've decided to stay with my stock Rom for now as I do like Sense UI but I wanted to Overlock so bad. The instructions on this forum made it a breeze.
I swear I wanna root, for Hotspot, battery, etc. I'm getting closer. Like I've driven to the water to take the plunge, but I'm still sitting in the car, looking at it through the window.
Somebody, anybody, give me the motivation I need!! I LOVE my Eris. But like I said, I'd like the Hotspost feature, and extra battery life I've heard about. Other than those, I'd like my phone to have the same exact look/feel that it has now.
Rapper gave you one motivation; I'll provide you two more.
- The new rooting method means that it is uber-simple to backup your existing "stock" HTC ROM (using Nandroid). You can always return to it (Nandroid restore) with four clicks of the trackball if you find the grass on the other side of the fence not so green.
- With just a little bit more effort, you can simple add root tools on top of your existing ROM. No need to re-customize your phone. (There is also a very simple way to "slip" a new boot partition into a nandroid backup so you can add a spiffy new OC kernel to your existing ROM)
Bottom line? You can have your cake and eat it too.
eu1
I'll add in my 2 cents now... I'll first start out by saying I've been back and forth between stock 2.1 (oc'd) and xtrROM. I have noticed a big difference when using stock 2.1 if you eliminate unwanted apps (that are safe to eliminate ofcourse).
If you use a file manager (Root Explorer) and browse to the /system folder you will notice that you have about 8 MB free in this memory space. After I removed a bunch of stuff I don't use, I now have a little over 20 MB free. I don't know with authority if there is a valid reason for this, but I do notice the phone to be more responsive and lag free. I would theorize that the extra free memory is somehow able to be used by the phone thus keeping it running smooth. I still run OC'd but I have taken the clock down from 787 to 710 without any performance loss that I can tell. It is also every bit as fast as xtrROM in my opinion.
At this point, I see no added value (for me) from using a custom rom. I do like xtrROM though, and I will try 3.1 when a few of the kinks are worked out.
One other thing... many of the custom roms eliminate apps so I have a feeling some of the speed enhancements come from this modification.
Hi LED,
Your post is right up my alley. I just rooted yesterday but I did not pick a ROM, still 2.1. I really only rooted to get a faster phone but I don't quite know how to get there. I have superuser and I've purchased setCPU but it stays at 528 no matter what I do. So now I'm rooted with a stock phone...arghhh I guess I have to do more reading![]()
So what you're saying is that it would be beneficial to remove the apps that autostart? If they don't autostart, then they won't necessarily slow the phone down, but they are just taking up phone storage space?
Correct. Keep in mind the phone storage space that is freed up will not be available for you to install market apps though... that's a different memory space. I believe that is part of the reason why some custom roms feel faster... they often strip out the bloat.
When I check my phone storage, it says i have 46mb free - this is for downloading and storage of apps, right?
When I check Autokiller (which I have set to aggressive), it says I have 58mb of free memory.
The latter is what will effect my phone's speed, correct?
I think I'm getting this. Haha.
