Wow that's wierd. Maybe its not shielded well or something. I need to get 3 or 4 more cables too. Anyone out there found one that works ok?
The one that comes in the box works ok for me
Is anyone running with SD swap? How large a swap partition are you using?
[Its updating to the final... yay!]
[B][U]Compcache Off:[/U][/B]
total used free shared buffers
Mem: 95948 77656 18292 0 376
Swap: 0 0 0
Total: 95948 77656 18292
[B][U]Compcache On:[/U][/B]
Mem: 95948 77832 18116 0 220
Swap: 25592 15096 10496
Total: 121540 92928 28612
[B][U]Compcache ON, SD Swap (212mb):[/U][/B]
Mem: 95948 76380 19568 0 192
Swap: 212028 11368 200660
Total: 307976 87748 220228
[B][/B]
[B][U]Cache/Swap status[/U][/B]
[B]COMPCACHE ONLY[/B] [B]COMPCACHE & SD SWAP (212mb)[/B]
cat /proc/ramzswap
DiskSize: 25600 kB 212039 kB
MemLimit: 25600 kB
NumReads: 3711 2351
NumWrites: 7305 8106
FailedReads: 0 0
FailedWrites: 0 0
InvalidIO: 0 0
NotifyFree: 3405 5247
ZeroPages: 68 60
GoodCompress: 79 % 100 %
NoCompress: 1 % 0 %
PagesStored: 3705 2228
PagesUsed: 1814 951
OrigDataSize: 14820 kB 8912 kB
ComprDataSize: 5110 kB 2264 kB
MemUsedTotal: 7256 kB 3804 kB
BDevNumReads: 515
BDevNumWrites: 1567
]Well, I installed the new NPS software, updated to II5 with Odin, and flashed the 4.1 recovery image. Took about fifteen minutes all in.
Now I just need to decide between the Galaxo and GalaxHero ROMs. Anyone got any thoughts, or just try both and see? How speedy is the GalaxHero ROM anyway?
im running galaxhero with swap enabled on class 6 card (created using 0.41 recovery)Well, I installed the new NPS software, updated to II5 with Odin, and flashed the 4.1 recovery image. Took about fifteen minutes all in.
BTW if u mean the internal memory widget, thats storage space and not RAM. Badly worded widget name!
