cool![]()
Turn on compcache from the galaxo config app. The whole rom is quite fast, i'm really impressed! So much so that i'm confident I wont be reflashing soon, and finally installing all the apps I usually use on the phone!
Seems the problem was with google apps backup. Cleaned the internal SD card of all old files, reflashed II5 again and now it's working.
before when I restored the apps, it was almost instantaneous, now it took ~8 seconds.![]()
[I used to work in GSM
]I just had a thought. The Galaxo config has a setting called 'provisioning' thats used to allow you to boot the phone with no sim. Maybe thats confusing the settings. Try turning it off and rebooting.
EDIT: didnt work here.
Wierd it used to sit there on my phone forever. Only way out was remove the battery. Maybe a new bootloader then.
If i click sensor then put my finger over the sensor (the one next to the speaker), the screen background goes blue, the phone vibrates and the value changes to 1. And back to normal when i move my finger.
ok scratch that.
It seems to be a one off error. Seems to be working after a reboot.
