heythereitsv
Since JMZ's Evoville Sense 4 thread was closed (don't exactly know why), I think I should post the fix for Sense 4/4.1 here. Here's some proof that it DOES work. Running Sense 4.1 RLS 3 from Chubbz on the Evo 3D forum.
Proof below!
http://dl.dropbox.com/u/75805861/Screenshots Sense 4.1/Screenshot_2012-09-27-17-07-16.png
http://dl.dropbox.com/u/75805861/Screenshots Sense 4.1/Screenshot_2012-09-27-17-08-10.png
http://dl.dropbox.com/u/75805861/Screenshots Sense 4.1/Screenshot_2012-09-27-17-08-38.png
Anyway, here are the steps! *DO THIS BEFORE FLASHING THE ROM!*
*I AM NOT RESPONSIBLE FOR ANY DAMAGE THAT HAPPENS TO YOU, YOUR PHONE, YOUR FAMILY, OR ALL OUT NUCLEAR WAR!*
1) Open up /system/framework/framework-res.apk from the Sense 4 ROM
2) Navigate to /res/xml within it
3) Open up /system/framework/framework-res.apk from the stock VM ROM (any Sense 3.6 ROM with MMS working on VM will work)
4) Navigate to /res/xml within it
5) Drag and drop apns.xml from /res/xml in the framework-res.apk from the VM ROM to /res/xml in the framework-res.apk from the Sense 4 ROM
6) Reboot to recovery
7) Flash the Sense 4 ROM (which ever one you choose, my personal recommendation is Chubbz' Sense 4.1 ROM)
8) After flashing, mount /system in recovery (should be a mount menu in EXT4)
9) Open up ADB and execute the following commands-
11) Do a FULL factory reset (wipe data/cache/dalvik-cache)
12) Reboot into your Sense 4 ROM that has MMS working! Congratulations!
*READ THIS!*
If you are running Chubbz' 4.1 RLS 3 build (NOTE- THAT EXACT BUILD!), you can skip to Step 6 and use this framework-res.apk (prebuilt by me).
Proof below!
Code:
adb remount system
adb push *location of the framework-res.apk* /system/framework
*READ THIS!*
And yes. Although don't upload the ROM with a fix baked in (unless you have permission from the dev), if you can make a flashable zip, that'd be great
