Root [FIX] MMS on Sense 4/4.1!
Thanks, but one more question. :p
Are we getting a flash able zip?
The procedure in order to get mms working looks a bit complicated. (x
As I stated earlier, the fix is on a ROM by ROM basis, so you have to do this with each individual ROM's framework-res.apk. I did Chubbz's ROM's in the OP, so you can just use that one for Chubbz's. So for example, I can't use the one I used to fix MMS on Chubbz's ROM on Tribulattifather's ROM.
Recovery? HBOOT? S-OFF or S-ON?
If you're on HBOOT 1.04, flash a different one (JuopunutBear works), or use another kernel, it should fix the issues. Also, what do you mean no ROM will boot? And the HTC splash or the boot logo of the ROM?
After about 4 hours I got it all sorted out via the RUU. I was using 4EXT, HBOOT 1.04 and s-off.
Installed for me on 1.04 although the boot animation doesn't show up. I also could not get the .apk to push for some reason.
Here is the command I used "adb push C:\Users\Anonymous\Desktop\EVO 3d RomS /system/framework*
look right?
Chubbz's build doesn't like to boot on HBOOT 1.04 for me, apparently people have gotten it working with a different kernel though. You didn't have to go through the trouble of RUU'ing and redoing the whole root + S-OFF process :(
Is the framework-res.apk in your EVO 3d RomS folder? Because if it is, the correct syntax would be "C:\Users\Anonymous\Desktop\EVO 3d RomS\framework-res.apk" /system/framework. Yes, the quotes are essential, since there's a space in your filepath.
look right?
No because this "fix" doesn't work on my rom
What base are you using? I'll try and look into why it doesn't work on your ROM...
Here's what I did and didn't have to use a computer. I unzipped the Rom, replaced the file, and rezipped.
I did all of this through es file manager.
I am currently using this Rom on hboot 1.04, with the kernel that is on the Rom.
Also to, I used TWRP.
If you do this method mentioned, DO NOT UPLOAD for others to use without asking the dev for permission.
^This will also work. I do recommend using the method in the OP, it allows you to have a clean version of the original ROM in case you swap out the wrong file or accidentally screw it up. And I cannot stress this enough- don't upload the fixed ROM (as a whole) without asking the original dev for permission!!!
Cool maybe will try again later, for now I'm liking this latest mobster. Is there anyway to get rid of the launcher on chubbz 4.1? I would rather have plain stock 4.1
Get rid of the Sense launcher? I believe the AROMA installer that Chubbz included includes an AOSP launcher option.
I get this message after entering the cmd. Is this a success?
3216 KB/s (6586801 bytes in 2.000s)
Update: After step 11 no boot animation anymore. Also, no sms or mms?? :(
Yup! And yeah, there won't be a boot animation, looking into that. And the SMS shouldn't even be touched while the MMS works fine... can you copy paste the settings from the MMS connection settings? (go into Messages, hit menu, hit settings, hit MMS settings, and hit Connection settings)
TBH though, it seems like a bad flash or a bad ROM if your SMS is broken...
LOL found the issue shortly after that post..my plan was up right before I flashed:D No wonder I couldn't send sms, derp
Have you tried throwing in a new boot animation via a file explorer? Will try and update post
Update: Service back on, however MMS still not coming through after the fix
Mms connection settings
Lolol good job. xD
Wrong settings. If you did the fix correctly (make sure you're using the apns.xml from a Sense 3.6 ROM for Virgin Mobile!), it should show the settings in the OP. These settings are for Sprint.
Also got an "error 16
I am having a difficult time snagging down how to create and resign the framework-res.apk. I have found a really sweet looking Rom http://forum.xda-developers.com/showthread.php?t=1925799 . I would like to fix the file to get mms kickin.
If anyone likes this Rom as well and has the ability to tweek the file, could you post the file (framework, not the Rom zip)or e-mail it to me?
:confused:
Thanks in advance for whomever does!:)
:confused:
That looks like a good ROM! Can't test right now though, I'm busy with school and I need my phone up and running :( But you don't need to deal with signing at all. Just drag and drop the apns.xml from 7-zip/WinRAR/other .zip file manager. Remember to do a factory reset afterwards! This is quite important ^_^
Lolol good job. xD
That seems like something related to your service... might just be a fluke, give it a couple of days and give VM a call if it doesn't clear up.
Hmm, maybe I pushed the wrong file. You have to wipe data, cache, and dalvik right?
Anyone ever use ninjamorph? You can modify apk's without messing with the permissions (so they say). Anyone ever use it? I've read of some folks using it to theme roms. I am trying to find a way to do the main idea in the steps w/o involving a computer. (my wife thinks I spend too much time on it as is...maybe I just need to format and replace her. That could be the issue, lol).
Lol, if you figure out a way to flash a new wife make sure I'm the first to know
The framework file you uploaded works with chubbz-rls3.fixed right?
Cmd is now saying "no space left on device"
Haven't heard of it. Heard of Metamorph, but that was way back in the Froyo days, before CM7 and its wonderful theming engine.
Yup. Did you do a format all partitions (except SD) before flashing the ROM? Also, what tweaks did you select?
