I'm also having the problem on my rooted Moto Droid (Android 2.2.3, ROM Mgr 4.8.0.7) if I flash SPRecovery it works once and disappears, in order to get CWM 2.5.0.1 to work I first flash SPRecovery (then CWM), but then another reboot (after using CWM once) that also disappears.
Since most of this thread is really old, I'm not sure which advice to try. There are newer versions of CWM but am too clueless to know if I can try anything newer, since CWM 2.5.0.1 is what ROM Mgr installed by default.
> Is flashing a newer CWM safe and/or would make a difference?
> Am I "partially" rooted?
> Some forums talk about downgrading Android to 2.0/2.1 is that something I need to do?
My goal is to get CWM working consistent/stable, then play with flashing custom ROMs. I would appreciate any suggestions anyone might have.
THANK YOU!!!!
