Root Flashing stock recovery
itzmiandy
Hey Guys..
I have been noticing that a lot of you are trying to install CWM on your phone.
Unfortunately there is no version out there which works on our phone. Will have to wait till someone ports it for our device.
Now for all of you who have screwed up your recovery. Here is the guide to flash the stock recovery
Download recovery - http://www.mediafire.com/?2556t5c2qaw4wwe
1. Make sure you have ADB or the SDK installed.
If you have rooted your phone successfully then you must have it installed.
2. Download the files from this link : platform-tools.rar
3. Extract the downloaded file to a location of your choice
for example - D:\SDK
4. Now go the folder, press the shift button and right click. You would see an option 'Open command prompt here' - click that to open command prompt.
5. Connect your phone switched off to the pc and press the volume down button and the power button for 10 seconds. You should see the micromax logo.
6. In command prompt type "fastboot devices" without quotes and hit enter.
7. you should see something like
List of devices attached
XXXXXXXXXX device
8. Now copy the recovery.img to the same folder you had extracted the files earlier.
9. In the command prompt window, type "fastboot flash recovery stock recovery.img" without quotes and hit enter
10. After you get a confirmation that flash is successful.
11. Remove the phone and boot into recovery. VOILA!! stock recovery :D
Show your appreciation.. Hit the thanks button..
HEY BROTHER ,
SO, new phone ....!
Does it has ICS?
No Bro,
It runs 2.3.5 only but I think ICS on this phone will be easy.
1 GHZ qualcomm processor.. Touch screen response will just WOW you.
The best part about this MMX is that it has no junk files inside..
Do you remember how we had to locate the XML file for the lockscreen?
We had to try one by one.. But this phone has only only the files that is necessary..
So makes our life a lot easier.
I got mine for 5799 and I would say its a steal.
Bro , I want you to get its Rom out for Micromax A 75.This will be a pure upgarde for
our a75 ,if successfully ported.
Except look anf feel , what is different in this (that was not in gingerbread)?
Hmmm nice phone congrats bro and haan dont forget us(Ur A75 buddies) after getting this phone hope we can have more things switching now between OUR MICROMAX DEVICES.
Few bugs reported in A87 ninja 4-
1. Very less free ram
2. Bluetooth recieving problem
3. Su broken. (Can u pls explain how u got root?)
And amazingly es file explorer is the default file manager :D
Yup you folks are right.. Micromax has cut down costs by not including a front camera and flash at the rear camera...
But for users like me, it does not matter at all..
Otherwise, the experience so far has been really good. Awesome touch response.
I dont know if these options are available in other models but here is the list that I love the most
1. I will be able to set different caller tune for sim1 and sim 2
2. I will be able to adjust the vibration strength
3. Reject calls with a message
4. Automatic redial and preferred callback
5. Preferred installation location in application settings itself
6. Flip to silent and shake to next in music, fm etc.
7. Horizontal screen resolution
8. Task manager with single tap to close all open application..
I am all game to port it to the A75.. But I need all your help.
First of all, I need to know how to get recovery working on my device - A87
Only then I will be able to get a nandroid backup..
Please let me know anything else I need to do.. I am GAME for it
i think 256 mb ram, 512 mb rom and no front camera
is it right
U r right but shows internal memmory 180MB
I have extracted System.img of Ninja 2, Ninja 3 and Ninja 4 these are same
But processor are not Mtk Based So this Rom not working In A75
Boot loop in A75 I have teasted.
Ninja3 and 4 only difference or screen and screen resolution.
Other thing Most positively these are upgraded to ICS.
For Rooting I Give the thred For Ninja 3 But All Ninja Phone can be Root by this method http://androidforums.com/micromax-a75/617889-rooting-micromax-a57-ninja-3-just-5-min.html
In this phone Mainly problem with Ram, I think Problem Solved by custom rom So I working on glaxy dueos for port new Custom Rom For All Ninja And Publish As Soon As posible.:):):)
This is awesome..
@Sagar, bro we need to get recovery for these models..
and my suggestion bro.. lets try to get ICS on the phone. Lets not waste time with Ginger Bread.
Let me know your thoughts.. I am here to help.
if this devices supports ics in future I will buy it
If anyone invest a little more ,can get MMX A100 where he can have
ICS ,5mp camera ,large screen .(I have seen video reviews on youtube of A100.
Looks great)
In my view ,A100 is better deal.
In future ,cost of A100 will also go down.
Looks great)
but I hate that 5 inch screen
4 inch is the best choice for me
plz provide the stock rom of mmx a87
i am confused
now if i root according to the method of a57
then after sometime if i factory reset or hard reset from android recovery then will i get the unroot stock rom or the rooted stock rom?
Hi Sagar,
I need your help..
I need to get CWM recovery working on this phone as soon as possible..
I have a few roms that I want to try out. Plz help!
Guys, i need the ROM ASAP. my A87 boot loader is corrected, i tried to install CWM recovery. It crashed the boot. its still stuck up in boot screen. I could not found any ROM or any solution over net, looking for help..
