Root Flashlight Problem After Upgrading To GingerBread - Help Please
Xunny
Hello Friends,
I have HTC Desire and a few days back I updgraded the software from Froyo 2.2 to GB 2.3.3. After the upgradation the Flashlight neither works as a widget not it is working in camera app.
Later on, I successfully rooted my device and installed and tried 4-5 different ROM's but the flashlight problem is persistent. I am getting really frustrated please help me friends.
Thanks in advance.
I tried these:
-- LeeDrOiD_HD_V3.3.3_GB-Port-R5-A2SD
-- Reflex_S_2.1.7_LITE_GingerBread_Sense-2.1_GRI40_A2SD+
-- DesireGRedition
-- [ROM] CyanogenMod-7 for Desire
-- Desire Gingerbread 3.14..405.1 | A2SD Base official HTC RUU |Android 2.3.3
-- GingerWally_v1.5 (Current One)
When I upgraded from Froyo to GB , I did so with RUU from Htc Developer site.
Sorry bro, I am unable to understand what exactly you mean by 2.2. Do you mean to downgrade to 2.2 again or what ?
flash an android 2.2 based custom rom and do a full wipe when you do. Then before restoring anything, test camera flash.
I was unable to install any 2.2 based custom ROM :-s as the installation aborted while flashing the ROM :( . So any idea ?
This is the exact error message which I got while Flashing 2.2 based custom Rom:
" Amend scripting (update-script) is no longer supported.
Amend scripting was deprecated by Google in Android 1.5.
It was necessary to remove it when upgrading to the ClockworkMod 3.0 Gingerbread based recovery. Please switch to Edif scripting (update script & binary) to create working update zip packages.
Installation aborted."
And, I tried further 2.3 GB based custom ROM and they flashed successfully without such error (as above) but FlashLight problem still persisting.
Please, guide !!
Please, guide !!
you are using a new version of cwm that doesnt support older roms because its stupid. thats why you have that problem
on all of our guides we have recommended that if you are on a erase size of 20000 you should use 2.5.0.7 and if you have 40000 you should use amonRA 2.0.1 which are both available from our root tools thread.
do not use the newer versions of CWM for desire
EDIT: you are not stupid, the recoveries are. no legacy support
what i said
flash a supported recovery using fastboot (if you are s-off) and backup the current rom
wipe device and flash a 2.2 rom using the supported recovery
I found that thread and read it carefully, but just wondering which Recovery Image version should be flashed ? :-s I am confused a bit :(
You can always use Amon RA 2.01.
If your erase size is 20,000 you can use ClockworkMod 2.5.0.7. Instructions for checking this can be found in the rooting FAQ, specifically this section (though I'd recommend reading the whole thing if you haven't already :)).
Do note that nandroid backups made with one recovery (CMW or AmonRA) cannot be restored using the other one.
I have Flashed ClockworkMod Recovery 2.5.1.8 and Flash a 2.2 based custom ROM and sadly the main issue is still there :'( Flashlight problem is still persisting :s Really frustrated now :(
Next step is to run a 2.2 RUU to take it back to stock. dont forget if you're s-off, you now need to fastboot flash (See faq in my signature - forget adb stuff) the alpharev.nl downgrade.img hboot to allow the ruu to flash over it.
Am I supposed to use these commands :
fastboot flash hboot example.img
fastboot reboot-bootloader
*replace example with the name of the img.
Please, confirm :-s
