Forums for Android™
C1. Multiple Devices
It was counter-intuitive to locate the area where devices other that the one I was using could be selected as a favorite. You would need to know beforehand what the structure was before you would ever go searching for it.
... Thom
C2. Multiple Devices - Sort
The entries are not sorted ... preferable would be alphabetical like ...
Motorola Droid
Motorola Droid Maxx
Motorola Droid Turbo
Motorola Droid Turbo 2
... Thom
C3. Multiple Devices – Content
There are a very limited number of devices listed. In for Motorola.
None of the modern Motorola devices are listed.
... Thom
C4. Multiple Devices – Motorola Droid
The Motorola Droid forum/channel always has been a source of confusion. It has been a collecting point for a lot of misfiled Motorola products that had names starting with Motorola Droid. A lot of people never realized it was the first model delivered.
Segregation by age helped. If there were models over 3 years old and models 3 years old or younger it would help.
... Thom
C6. My Stuff Format
The My Stuff area should be laid out the same as the Timelines area ... a logo and title and then underneath it the text spanning from the left edge of the screen to the right edge of the screen. There is a lot of dead space on the left side at the present time.
... Thom
C7. Like Counts Missing
I have a post that when listed using Internet Explorer on a Windows 7 desktop lists one Like.
When I list the same post in My Stuff it does not indicate that there are any Likes.
This is more than 8 hours after it was Liked.
... Thom
The post title I read previously stays on top of the thread list.
I didn't even see the 3-dot menu because of the poor contrast with the dark theme. But the only option it gives me is "report", seems it doesn't recognize that it's my post and I should have an edit option.
(I couldn't even FIND this thread via the app to post this, so having to post from a desktop)
Firstly, I know people are working hard on this and it must be very discouraging to get so many people grumbling. That said....
(Using from an LGV20)
- interface is really confusing. The whole "+" in a circle to change views is very counter-intuitive, as every other app I have uses "+" as an indicator of a new post or message. Even more counterintuitive is having to hit "back" to go to the previous view. How about another icon in a circle to keep it consistent and let you toggle between the two views? Or even tabs at the top that you can slide between to find all those lists/categories/ways of viewing?
- It crashes if I switch between the timeline view and forum index and back again.
- colorscheme is not wonderfully vision-friendly, particularly "faded" options.
- titles are big, but text is small.
Sorry to be Debbie Downer, but it's still not a wonderfully user-friendly client - thanks for your efforts and I hope the feedback helps!
Did the app just break for anyone else? It stopped loading content and I tried logging out and back in, but it FC's as soon as I try to submit my login info.
Curiously this happened just as the discontinuation of Tapatalk was announced-
Also as the https was initiated, I'm guessing that might be the likely candidate. Yes I have FC's or a black screen depending on how I log in.
Same problem as above. Submitting log in information results in a crash.
Thanks Steve- it's back, but still getting FC's while browsing (although it does recover by itself after the FC) and some content isn't loading. Previews in My Stuff are going to the first post rather than the most recent.
Update- clearing data seems to have helped with the FC's, but I can't see any content in the device forums unless I suscribe to them.
Pushed an update (as well as updated this thread) with v1.5.3.0.
Main changes:
  • 2-Step authentication support
  • https (all app/server using SSL)
I have a bunch of other updates coming but wanted to get this out to support our https update. Sorry for the delay!
Aye aye. Got the new version and two-step worked like a charm. :thumbsupdroid:
... Thom
I agree that this is not the best. I will have to brainstorm with @Rob and think of all user cases... and figure out how we can improve the flow of the app and/or app setup.
Motorola Droid
Motorola Droid Maxx
... Thom
Currently, there are only devices listed on that tab in order of popularity (which is still weird since we are still getting more users and new channels are still being created). If you search for Motorola, this would (or should) show in alphabetical order.
I am planning to add sorting/filter bar to each tab on that activity in the screenshot.
... Thom
This will get fixed over time... I will also check if there are any pending channels that need to be approved that were not automatically approved without look-up table.
... Thom
Interesting idea. I think that once we get filtering setup and you can easily sort by popularity, users, etc... this may help. Anything else would be manual moderation of some sort to separate those... even if it would be adding an extra year column in our channel table to filter/sort by. Will put more thought into this.
C5. Verizon Wireless
The placement of the Verizon Wireless forum/channel in the attached screenshot is strange.
View attachment 117893 View attachment 117894 View attachment 117895
... Thom
There is a bug with the Verizon icon for the favorites... I will test and fix that. Could be resolved already but I will confirm today. I will also look at sorting the Favorites too.
C6. My Stuff Format
... Thom
This whole tab will be replaced/fixed soon. I was holding off due to other priority issues and dependant API changes but I can start planning/designing this out. Feel free to give suggestions as it sometimes is hard for me to see the perspective from users since I am always coding/testing/coding/testing and not using the app consistently as a user would.
... Thom
You should never use Internet Explorer and Windows 7 in your complaint :)
On a serious note, I will just make sure this is fixed or doesn't happen when I redo that tab.
By design, if click on the parent breadcrumb (channel)... it would should the last thread you viewed. There is a bug that I am currently fixing that this breadcrumb (thread title) would remain after closing the channel/thread and opening it again.
When in a thread, scrolling down makes the reply button disappear. I have to scroll up to get it back.
This is by design. The FAB is a nice quick action but always is in the way. Common UI/UX is to hide on scrolling. Did you have a better idea on how to handle this? Maybe another app that does something better? It should hide when scrolling towards the bottom of the list and also hide when you are at the bottom (to prevent interfering with the pagination bar.
Also the back arrow in the header area does nothing until I pull the header down to expand it. And I had to make this post because there's no edit button.
Indeed. Nice catch. I will fix this.
The 3 dots sometimes has an Edit option.
The New Post button would cover the navigation.
Can you confirm that this is still happening? We had a security issue that we had to fix, which token scopes were limited during this time. The pop-up menu should overlay the FAB. Is this not the case for you?
I will do some testing on the dark theme to change contrast as needed. I think it comes down to issues with the dark theme when you have a less than 50% brightness (plus could be different for everyone and how they see darker shades).
Thanks for the feedback! We are constantly trying to improve the UI/UX so I will note all your suggestions. Could you elaborate on what exactly in the color scheme you dislike?
I hopefully will have fixes for these crashes today. I will check your support id for your particular crashes as well to see if I find anything new.
Awesome! I will be improving the flow of this a little more as well as fixing the whole sign-out and clearing data as expected. I was up late last night and wanted to get a build out for the https support. Have some other changes pending that will be in the next build. Thanks for testing!
While I like the button, I often find myself scrolling back up to get the reply button as I may not want to quote the last post. I'll offer feedback, but the app is hung at the moment and I can't picture how it looks in my head.
