As dsavage so graciously pointed out in my previous post, as one way to install apps.I flashed 2.1.2 today to see what it is like compared to Fresh Toast 2.1 and 2.1.2 is faster and quicker. Added the SU fix, so hope that works. Want to push the OMADM.apk fix from xda that is supposed to fix the PRL issue, but I am confused as to how to push it to /system/app. Anyone care to point out the steps?
go to folder where you extracted sdk tools. make sure adb.exe is in there. launch command window from that folder (or navi there)
then:
push <location of APK file on your computer> /system/apps/
while phone is connected to pc. about to see now if i can prl update.
anyway, that's what I did to which I got
adb server is out of date. killing...
daemon started successfully
846KB/s <163598 bytes in 0.171s>
The part about being out of date concerned me so I ran twice. So I ran again and got
923 KB/s ,<162598 bytes in 0.171s>
So, it would appear it took. However, I still get the terminated unexpectedly msg. when updating PRL. YMMV... I don't even know what the use of PRL, Profile, and Firmware are; and how meaningful any of 'em are. But I did do the radio update and su fix after installing 2.1.2.
going back to my previous post, I am thinking 'bout getting a Innocell 1750mAh Slim Extended Life Battery just to combat this battery issue I'm having, but have a feeling the difference in mah will be negligible. Anybody else try it yet? The larger 3500 mAh one I'm sure gets a palpable increase, but to the detriment of an ugly turd ergonomic.
