The best way is to charge the battery while in the recovery mode.
Pull battery, then reinsert it. Hold HOME + VOLUME DOWN, then push the POWER button. Hold all at the same time until you see the LG logo.
It will take less than 30 sec. for the recovery menu to be displayed.
Plug phone into charger.
Leave on charger for half hour. Select to reboot system now after time is up.
If it boots into system, great. Finish charging.
If not, the wall unit, the USB cord, charging port, or the battery could be bad.
Note: If you could not see recovery menu (black/blank screen), plug phone into charger for 30 minutes anyway. Pull battery and feel if it's warm. If yes, get back into recovery menu and see if it will display. If yes, leave in recovery menu for 30 minutes.
If battery is not warm, then wall unit, USB cord, battery, or charging port is bad.
