Is there a way to get percentages for how much of the time it was awake and had wifi, GPS, and screen turned on? Apart from wifi, it's tough to tell from the graph.
It's relative. People were expecting more because other LTE phones seem to do a bit better. FWIW:
There were early some battery issues with iPhone4S, but I believe that has been mostly resolved via software update (someone correct me if I'm wrong... I don't have one myself).
From what I've seen and read, and my personal experience with iPhone4 and 3GS, iOS is better at power management. To be fair, the iPhone has ~39% less screen area than the VGN and no LTE, but is also has a much smaller battery.
Charged ny extended barttery overnight woke up at 7am, been on the phone since then now its 839 . Battery is down to 55% . An hour and half of usage down to 55%.. can this be normal?
Depends. Is this your first day on the extended battery? It's obviously either an incorrect battery level indication, or something (phone or batt) is defective. The only thing normal is that if it's the first charge & first day of use, you can expect to have to go through another couple charge/discharge cycles to get everything ship shape.
I had my phone at 830am on thursday lol
Today I got excellent battery life. After 7.5 hours I was at 50%, did a lot of web surfing and texting. At that point I decided to charge back up to 90% and download my entire music collection from G-music, 10gb worth. Music is currently at 86% complete and battery is at 4.5 hrs at 17%, not bad at all for the 80+ pictures I took tonight, web surfing, app downloads, and screen on at 50%. No complaints about battery life.
I conditioned the battery prior to first use and I beleive it has helped.
Dayum...
Hey, when you say "on the phone" you mean talking on a phone call the whole time, or goofing around?
Either way, that sounds abnormal.
Wait wat? Google music catalog has to download to your phone? I thought it was all streamed? Or do they just down load a piece of it to get it started immediately every time? Is this the same with Picasa?
I wonder if this is an issue with causes of poor battery life if you are unaware if it is doing its thing in the background...
I took mine off the charger last night at 100%, around 12am. I slept until like 9, and used the phone for texts and calls all day. The phone died around 3pm after I played angry birds for a while to try to get it to die.
I don't really see much of a problem, I'm used to horrific battery life after my incredible. Charger at home? check. Charger at work? check. Charger in car? check.
Thus is the life of a smartphone user
Okay, tbis may be stupid but how do I tell the difference between the extended battery door and thw standard? Ive gotten them mixed up. Stupid, I know...
This is on the extended battery. First go around with moderate to heavy usage, I got 12 hours out of the first charge. Second go around with light usage, mostly in standy, I'm getting:
Now, the Android OS is sucking up a lot of battery in standby, as mostly everyone has noted. However, knowing that it can only get better from here, I'm very happy so far considering this is an LTE device.[/QUOTE]
Dude! Your phone is a BAWSS (see any Rick Ross video for a definition)!
The extended battery door will have slightly rounded/curved edges. When attached to your phone, the extended battery door will sit flush with the hump at the bottom of the phone. With the standard door, it'll sit thinner than the hump.
