BabyBlues
Trouble Just Finds Me!
I left my Bluetooth on all day today... no real effect on battery life ; after 17 hrs I'm at 72% .
Damn, did you use the phone at all??
Out of lurk mode to ask a question:
I've been researching usb car charger adapters to get one that works well for charging the Nexus with equivalent power to the AC adapter. From what I've read, most adapters will be treated the same as plugging your phone into your computer and therefore draw less current than the wall charger. There is a mod you can do which involves taking the thing apart and soldering the D+/D- pins together. I don't really want to do that. Has anyone had any luck finding an adapter that will let you draw 1 AMP?
I found the following thread on here that discusses this issue, but it doesn't seem to have any resolution: Charging: USB and AC differences - Android Forums
About the diet part of it...what about for pregnancy? as my wife is carrying 12 weeks. I'd run it by the doc anyways just thought I'd prod you![]()
Generally the rule of thumb is that its OK to continue a program that you were using prior to pregnancy. I've had woman deliver the same day the did a cycle class . Most of the time the dr gives them an HR limit.
This charger has been claimed by several people in another thread to provide full AC-level charging.
Yeah we tested Skype and for some reason I have to hold the phone upside down or she gets an inverted imagebut once she is in G+ I'll try Messenger... thanks!
But hey: Skype WORKS! Whoot
Thanks, I'll check these out! I was thinking about getting a dual one.
Edit: Strike that. I looked up this adapter on Amazon and reviewers are saying that it has the same problem. Have you been able to verify you are getting 1 amp from it?
Griffin Powerjolt Dual Universal USB Micro
I can vouch for the Griffin products. They are great. 1 amp (1000ma) like the Griffin and the one in the picture you posted is the same output as the stock GNex wall wart. If I could find any with 1.5 amp I would try those too.
I am also thinking of trying a 2 amp tablet/ipad wall wart plugged into the inverter in my truck. As long as it is 5 volts, the extra amps wont hurt a thing.
Yeah, thats why I was trying to find one rated at 1 amp. The thing I'm questioning is whether that is what you are actually able to draw from it though. Some people are saying that your phone can't distinguish whether it is a data connection or a charger and limits the draw to 400 ma.
Actually, no. I dont know where to check a usb with a multimeter or I would.
Did you get "Skype" or "Skype mobile for verizon" (or something like that). The correct one in the market is just "Skype".
The family i skype with tell me that the picture and sound is equal or greater that my laptop. And I have a good laptop. I usually use it from wifi at home, but have used it with success driving down the road in 4g. I will check on changing the orientation thing, but I hold it in landscape with the front camera to my left. It works with my bluetooth earpiece great. It has much better video quality than Google+ via messenger for me.
Well, my current hunt is failing so I am hoping someone here can point me in the right direction. I have been searching on XDA and Rootzwiki for a themed ICS keyboard and can't find anything. My internet is acting up right now and its taking 2 minutes to load 1 stinkin web page so my search as been painful...but if anyone can point me in the right direction to some themed, stock ICS keyboards that'd be great!
Thought I would share here.
Extended Battery
Not light use, not heavy use
3 hours of xm app streaming
2 hours getting a stock tether app to work
a few phone calls
majority of the time on wifi
emails and tweets
a few pics
30 minute skype call with video
Any recommendation for a business card scanner, that will pull what I need into the address book? I'm using touchdown, so not sure if I need something specific for that program?
Thank you.
