If I ever have to do anything like that to my phone again I'm starting in the morning. After I was set I ended up flashing twice more.
Don't ask, it was me being slightly 'special'
haha i wish i could plug in external RAM AHH aint that an idea for a invention
that android as we know it will die is a bunch of bs ... yes i see a good sizable shift from flash based to HTML browsing but saying that the Linux quality will change the openness and all that makes me hot under the color sorry had to get that out
/rant
21 hours of talk time on the new Razr Maxx...might be enough to give that a try...just sayin!
Gave blood today. It's 8 pm and I have an hour to go at work. I feel more tired than usual. I wonder if that's from the loss of blood?
I was afraid that might damage something. Okay, I'll try it. Thanks.Razor you can pull the battery and boot up normally. Dnld a 4.0.2 compatible boot ani and flash it like you just tried to do.
gave blood today. It's 8 pm and i have an hour to go at work. I feel more tired than usual. I wonder if that's from the loss of blood?
I was afraid that might damage something. Okay, I'll try it. Thanks.![]()
I second this. I'm not able to give blood anymore either but thanks to all who do.
How did your daughter's MRI turn out the other day? (Or was it ct scan or surgery?) Regardless, I hope she is well.
Is that better or worse than exceptional?![]()
Actually, it was a hida scan that determined that her gall bladder had to come out... and it did! Other than some expected pain, she'll pull through nicely. Already back on the greasy cheesy foods she couldn't eat before
Thanks for the concern and well wishes, BB!
Why hello there peeps.
Hey stranger ! How goes it?
Oops! Too late, I already pulled.Wait! Before doing a pull try what I said with the go back highlight option. You most likely successfully flashed the boot ani.![]()
Alright, perhaps I'll try this again. Thanks for all your help!Razor when you're flashing in CWM and scrolling with the volume button, whenever you go down beyond the last item (so the highlight will now be atop the menu), then back up past the top item (so the highlight will now be at the bottom), then back down beyond the last item you have disabled the "go back" button that appears on every menu until this happens. To re-enable it do the above. Hope this explains it well, it's always been like this in CWM and with the wonky scrolling in cwm 5.5.0.4 it's easy to accidentally do.
If you've disabled this "go back" selection (which you did) it won't reboot and just sit there like it has done for you. This happened to me once on the GN and I'd remembered from my Inc days how to fix. gl!
Busy. How are you doing?!
So does the AOKP rom work with google wallet? Still trying to decide what I want to do with loading a ROM.
