hey jbdan (or anyone else for that matter)!!!!!!!! If I extract a boot ani zip using root explorer, where do I put it to ensure it become the new boot ani. I have seen different things and on my last 4 phones it was always the same place!
jmar
jmar
That is what I thought!
Boo on you blkblt
jmar
/system/media didn't work!![]()
Boo on you blkblt
jmar
For those using nfc tags, how do you have a tag open multiple apps (i.e. Car dock and Pandora when I Get in my car.)? I have nfc task launcher from the market. Thanks!
I don't know anyone anyone local with a gnex so I haven't been able to play with the nfc.... Is it fun to play with???
Don't get mad you cuz you know you love me
So, I've noticed that Ubuntu has been mentioned a few times throughout this thread and was just curious how many of you use, or have used, Ubuntu? Are any of you like me, full converts?
I started with a 7.10 LiveCD (the compiz desktop cube was what hooked me), then I used WUBI.exe to dual boot 8.04 and XP on my old laptop, and finally ditched M$ completely when 9.04 came out. I currently run 10.04 on my desktop (which doubles as my media server) and the only other non-Android computer I own is a Chromebook (Cr-48).
In case anyone is curious about the hardware (it's my pride and joy, I built it a little over 2 years ago and I'm still upgrading it)
Open up NFC task launcher, create task, add new action, applications, under launch application there is drop down pick your app, then hit the + sign to the right of launch application. Do it as many times as you need to to launch the apps you want. Then hit the menu button (bottom right corner) and save that tag and name it what you want. Then hit Write Tag and follow the prompt it tells you to set it down on the tag. Voila!
