blkbeltkid17
Android Expert
Morning guys and gals
$7 for OEM charger (DROID Charge, but same model) with free shipping -- anyone know of a place to get it cheaper?
Amazon.com: Samsung OEM 1.0A Original Home Wall AC Travel Charger Adapter + USB 2.0 Data Sync Connect Transfer Charge Cable: CCMACCESSORIES
they also have the moto wall charger for $5.83 if you're really intent on pinchin penniesi bought this with the OG and use it on my gnex at work.
http://www.amazon.com/Motorola-SPN5504-SKN5004A-micro-USB-Charger/dp/B004EYSKM8
how do you like AOKP 15? i've been content with 14 so far. seems like the additional toggles are what may drive me to update, but otherwise i am resisting the urge to flash. i'm actually UC to 920 with LeanKernel and i honestly can't imagine wanting/needing to go faster. but then again i don't play games.
i like the centered clock cuz it's easy to get lost with several notifications battery/signal/mail/texts/TiBU/etc
What kernel are those of you on aokp using?
Just a general question for all you out there:
If you're using a case (I'm currently on a Rev. 3 Diztronic, but have a couple different TPU ones on the way), what if any cradles/car mounts work with them? My wife has my old Bionic and is the primary car driver so we'll likely just get a mount for it, but curious if any docks work with small cases like the Diztronic. (and by the way, it seems great so far)
Haven't seen a ton of changes, but I really like stock ICS with a couple tweaks. One thing I did notice is while I was at lunch and surfing the web for a couple hours, my battery completely tanked from full to nearly 50%. I'll try out a new kernel and perhaps some different SetCPU settings to see if I can manage any better. A little dissapointing though![]()
If you are "creating task" it shouldn't do a second read on one tag like you said it was doing. "creating profile" does this though.
Maybe try changing the order of the tasks you create? idk.
Which tasks exactly are you using for a tag and I'll try to re-create it here and see what I get. I just tried a 2 task tag (car home and Pandora) and both opened right up, Pandora first and started streaming my music, then I hit home button and it went straight to car home so car home was opened but not showing as Pandora app was at the forefront so-to-speak
Well, this is frustrating. I know exactly what you're saying, and even backed out of the running app, to see if anything was running behind it. Nope! I checked on several different tags. Same thing. I read the tags on another app, and the data was all there (all 3 apps.) So, I uninstalled the NFC app, installed Tasker (since, if you want to run tasker tasks, you have to install Tasker first), and then reinstalled NFC Launcher.
Then, it wouldn't even write a tag at all! I finally got another NFC writing app to write a tag, then NFC Launcher worked again. Trying on all different tags, it finally started working! At least I got 2 apps to run - Pandora (first), then if I back out of it, it loads the Car Home app. It wasn't doing that earlier. I had emailed the dev, and he's "looking in to it" so we'll see.
This is still WAY cool...lol. I wish I could get the nav app to run, but maybe with some time/updates, it'll work.
One thing I noticed, if I just created a new tag from scratch, when it would try to run that tag/apps, the item in the notification bar says something like "applied (then lists the various apps)." However, when I created a tag, saved it (i.e. "Car Dock"), it would say "Applied Profile Car Dock" in the notification bar (even though it's not a profile...just a saved tag). It acts like it doesn't read all of the apps if it's not a saved tag maybe?
On a side note, what bedside app do people use? I'll be putting a tag on a bedside dock that we are making, hopefully for production (more on that later.) I'd love one with clock, weather, emails, etc.
I got this a few days ago....HIGHLY recommend it:
http://www.amazon.com/gp/product/B004G1L52Q/ref=oh_o02_s00_i00_details
I also have the Diz R3 case, and it works great with this dock. It is stable, doesn't bounce around, and you can still get to the volume and power buttons while it's docked. I run the audio cable to the phone first, and run the power cable through the hole in the bottom before I dock it, plug them in, dock the phone, and voila!
Now that I have my NFC tag MOSTLY working, I'm as happy as a fat pig the day after Christmas!
Sort of. I just have a couple tabs that I keep open - this thread, the wallpaper thread, the homescreens thread, and the ICS tips & tricks thread.Do any of you even go to the actual Galaxy Nexus Forum anymore?
That looks like an awesome mount! Best of all, it'll work with both our phones and since she drives a Honda Fit, windshield space is limited and this will be great.
Love the fact they use the CD drive as a mount. I mean, does anyone actually play CDs anymore?![]()
Sort of. I just have a couple tabs that I keep open - this thread, the wallpaper thread, the homescreens thread, and the ICS tips & tricks thread.![]()
Lol. Yup. I do. I keep Nickelback or Papa Roach on standby.![]()
