Something isn't playing nice with the ability to change my menu buttons. Could it be nova?
Does anyone use some sort of collaborative solution for sharing documents? Specifically a simple Excel spreadsheet that can be shared/modified by 2 people without emailing back and forth? I dont know that it's absolutely necessary it stay in Excel so I started to look at Google Docs but also noticed they have Google Cloud Connect that looks like a plug-in to Office and am wondering if that would be better. Any advice on which way to research is appreciated.
Also, if there are any foodies in the room, my wife and I are headed out to one of DC's best restaurants tonight for a very belated birthday gift. Place is called Komi.
Wish us luck, should be a long and tasty dinner!
gl! And yum just the name sounds like it would be good to eat
I'm cookin', timer is going off! =o
Bleh, as a chef (and wife to one who works in catering), I never cook at home! Would love to get around to it at some point, haha.
Anyway, here's a recent review from the Post if any are interested:
Komi Review, Washington, DC - washingtonpost.com
Are you talking navigation buttons (bottom dock), or something else? I just updated to AOKP 15 and added the search button and everything is working great. (also running Nova, not sure which version)
Could be. I found Nova, and I know it's very popular, to cause funky issues on my phone when I tried it. Haven't been back.
Could you back up Nova, delete/uninstall it, then reboot to see if your having an issue? Then re-install when you're decided.
Which version of Nova do you have?Something isn't playing nice with the ability to change my menu buttons. Could it be nova?
I had this problem when I first installed Nova (beta 8) over RevolutionHD on Sunday afternoon. I continued to have the problem until I rebooted the phone. Later that night Nova prompted me to install an update (beta 9) and one of the bug fixes listed had to do with problems with unmovable icons. Since then I have received another update (beta 10) but I have not had a repeat of the issue with the app icons since the first day.
AOKP M2 is out... I recommend it as a good stopping point for upgrading. Its stable and awesome
Full wipe or flash over 15?
Wipe cache partition, format system under mounts and storage, wipe dalvik, flash M2, ready set go!
Thanks! Then Nova and battery mods. And kernel.
soooo i think a good thread on the propers of wiping and flashing would be greatly appreciated. back in the good ol OG days, doing flashing and wiping in ROM Manager seemed like all that was needed. it seems now everyone has their own preferred method of doin the deed.
what gives?
ps - everytime i think about it or type it out... i always stop and laugh. it's good to be in 7th grade again. wipe.
I would like to report that I am terrible at Dance Dance Revolution Hottest Party. TERRIBLE. Except for a couple of the faster songs. Go figure. *shrugs shoulders* The songs are horrible on it too though and that is irritating. I just didn't feel like going to the gym. But am hour of DDR seemed better than nothing.
