Galaxy Nexus Watering Hole
Running Codename1.0.1 with the Black and Cyan theme from Rootzwiki. Loving this ROM, extremely customizable, and I'm getting 30+ hours per charge with normal use.
Good lord, Tapatalk compresses those things to absolute crap. Oh well, you get the idea.
anyone running into BugMailer auto generated reports/emails?
i know it's not ROM specific (it's happened to me on Rootzboat and AOKP, can't recall if it did on stock). i've found a solution in renaming the system file, but i've been unable to find a cause...
i think what's weird is that the bugreport title shows mysid 4.0.2 ICL53F... i'm definitely running 4.0.3 IML74K
It is happening on stock. It's annoying. I'm not sure what's triggering it, I even wiped my phone clean, thinking a bad app is doing it, but it's not the case. I can't rename the file because I'm not rooted, how can I get rid of these generated reports OR rename the file (if that is a proven solution/workaround)?
chiming in over here to say that Codename Android is absolutely awesome. the softkey mods alone make this rom keeper for me. you can choose how many keys you want, what you want them to be(home, menu, back, search, recent), which order you want them in, and which color you want them to be all from the settings menu! :eek:
if that weren't enough, long press search to open voice commands is back as well! this is the first rom i have seen with that feature, and i have really been missing it. you also get built in options for % in battery, clock location, and a 3g/4g toggle in the notification bar. doesn't get much better!! :D
I'm contemplating trying this. :D
I forgot how much fun flashing is!!!
AOKP 16 came out tonight... another great build.. but I went back to Peter Alfonso's stuff... its stock as stock gets... but really fast and snappy. Not even the slightest but of lag when hitting the recent apps key or anything... although, I'll be honest. I do miss the extra features
It is very addicting! I think I've made 6 batteries now and edited hundreds of png's (all the % 0-100) :p
It just got updated about 5 min ago be sure to try 1.1.0
How does one get those mods to the phone? Flashable zip? Drop it somewhere in the system?
I will continue to hold off flashing (at least until saturday). I don't have time to set up everything again.
AND - you are all very bad for my wallet. But thanks for the posts on the charger (it arrived today), the car mount and the cable to use in the car. While I was on amazon I also came across a computer stand for my new desk and resistance bands.
For the battery, what I've been doing is making it in UOT, picking a generic CM7 rom as the zip I want built, download it once done, then extracting the 100 png's of the battery with 7zip and copying them over to an already done battery mod zip for aokp whatever build your on (like any of them) so it just replaces the images.
And I absolutely love spending other peoples cha-ching! :D
UOT will eventually support ICS, can't wait as then you'll be able to go through the hole gamut and completely revamp your UI to how you want and have the custom zip built. Won't be too much longer for ICS support from what I read on their thread @ XDA.
I'll wait till then.
Soooooooo jb? You gonna wipe and flash 16?
lol are you spying on me!
Reading the rootz forums now I like to give it an hour or so to see if there are any bugs and let all the crackheads flash first :p
Making my nandroid and doing a TiBu as well in preparation =)
wbu?
I am running Redemption Rom with Franco's kernel and actually getting decent battery life today. But now I am tempted to switch to AOKP....in your experience, could it affect my battery life, if I keep using Franco's kernel with it?
