RazorSharp
Android Expert
Nice! I think I should get my extended battery on Monday.Look what fedex delivered today!
It took me 2 times to get everything set right. Its one of my favorite apps now
Nice! I think I should get my extended battery on Monday.![]()
I had something similar for my OG and loved it so I had high hopes. I think I might have it set now. I'm going to leave sms alert control in gosms because I had individual contacts set up in there already.
Which reminds me, is there a non-rooted way to use the regular messenger logo instead of the gosms one in my launcher thingy?
nice!diggin the nail color too
Desktop Visualizer. Although I bought the droidicon app and used that for the icon. But a search of icons in Google might get you a usable pic as well.
ok, now im rooted and not sure where/how to go about getting CWM installed and running... anyone want to help a noob?
Does screen adjuster help with battery drain?
Confused. You gained root without flashing CWR via adb? When I rooted I pushed the Su zip to the SD, flashed CWR via adb then installed Su zip via CWR.
I doubt it will help. You are increasing brightness which increases the power demand. It sure looks pretty sitting on a charger though.![]()
I think he flash the maguro recovery and wants to flash Toro recovery via. Clockwork Manager...
See my above post ;-)
Was it easier to unlock & root the second time?
I have been Bragging about my Gnex to the iPhone crowd and when I showed them their jaws dropped.
80% of them will be switching to Android devices on there next round.![]()
Go into the market and download rom manager. Islets also called clockwork manager. Then hit the top button that says flash recovery, choose cdma nexus and let it flash. Then choose backup entire system and let it nandroid
not sure what any of that means.... but i went here http://androidforums.com/galaxy-nexus-all-things-root/452146-how-root-samsung-galaxy-nexus.html then went down to "superboot method", downloaded and extracted the zip, went into fastboot and double clicked on the (install-superboot-windows.bat) file
awesome! already had installed rom manager in anticipation of using it later, but it looks like this way much easier than i thought. i opened the app, chose flash clockwork recovery(CDMA), and now it shows current+latest recovery as clockworkmod 5.5.0.4. am i done for now until roms start coming out?
Wow those instructions are sooooo confusing. Koushes method is so much easier.
I remember the days of the old droid 1 when you had to adb push the files and then manually set permissions...
lol, ok, so im going to give a full rundown of what i have done in the order i did it to ensure it was correct...
1)installed all the sdk and correct drivers
2)got into fastboot and did oem unlock to unlock bootloader
3)downloaded the modaco superboot zip and put it inside my sdk tools under a folder i made(gnex superboot)
4)booted phone into fastboot using volume +- and power while plugged into cpu
5)double clicked file within the superboot file i downloaded called "install-superboot-windows.bat" , it automatically did everything from there
6)reboot phone and ensured superuser was there and indeed it was
7)downloaded ROM manager
8)opened rom manager and selected "flash clockworkmod recovery", and it now shows as 5.5.0.4 was the current and latest recovery
i think that is a much simpler summary than i have seen other places and might show people its not as intimidating as it seems
