SolidOrange
Android Expert
lol, ok, so im going to give a full rundown of what i have done in the order i did it to ensure it was correct...
1)installed all the sdk and correct drivers
2)got into fastboot and did oem unlock to unlock bootloader
3)downloaded the modaco superboot zip and put it inside my sdk tools under a folder i made(gnex superboot)
4)booted phone into fastboot using volume +- and power while plugged into cpu
5)double clicked file within the superboot file i downloaded called "install-superboot-windows.bat" , it automatically did everything from there
6)reboot phone and ensured superuser was there and indeed it was
7)downloaded ROM manager
8)opened rom manager and selected "flash clockworkmod recovery", and it now shows as 5.5.0.4 was the current and latest recovery
i think that is a much simpler summary than i have seen other places and might show people its not as intimidating as it seems
this is the exact method i used. honestly the hardest part was finding the right samsung driver (Samsung_USB_Driver_for_Moblie_Phones_v1_4_6_0.exe) and getting the adb folders set up correctly. everything else was a breeze!
