welcome to the forums!!!!!I am thinking of buying the Samsung Galaxy note would I be able to connect to my computer to download software if I do not have a separate plan
Complete Newbie would appreciate any advice
Than You![]()
not exactly sure what you mean? what software are you talking about?
edit: i moved the thread to the note 2(unless your thinking about the first note) forum as those who have the phone can help you better.
I have purchased the Note and was able to connect by WiFi to my modem and then download the software I needed is this unusual ?
The system I will be using to fly my remote controlled Quadcopter ( Heli with four blades ) uses android to provide the system to both setup and fly though it still can be flown with a normal Remote Control Transmitter wonderful technology from the East it is even possible to stick the phone in your pocket and the Quad will just follow you about
