Root GB and back to 2.3.340 HELP!
Sleek2G
Member
Thought I would make a thread (for help) on how to go back from GB 2.3.3 back to Froyo 2.3.340.
With all the commotion going on with the carriers and P3 dropping the bomb on us about the tethering and been tracked, I have seen quite a few people do the switch back to Froyo. I wanted to post this to avoid anyone to not do what just happened to me for not reading.
I was running GBrootedDeodexed and made the decision to switch back to Froyo. Well I decided to use the marderstock2.3.340 (bad decision) wipe data/cache and factory reset. Well that didn't work to well apparently, so here I stand with a bricked phone that only loads up until the Moto logo and wont go into recovery (factory recovery).
So yeah, HELP PLEASE!
My guess is to download drivers and RSD Lite and SBF back to 2.3.340.
TIA
EDITH: Taught I would update this thread to show the process on how to fix his issue.
RoOoLeR's Guide
This was taken directly from the rooler's guide, I take no credit or responsibility that come with it.
Quote:
***Required Files and Hardware***
Windows*
- Motorola USB drivers (Windows 32 bit) (Windows 64 bit)
- RSD Lite 4.7 Or RSD Lite 4.8 Or RSD Lite 4.9
- SBF File that Corresponds to you.
Linux Utility*
sbf_flash - source
Linux Distro's*
Ubuntu
Debian
Puppy Linux
Pocket Linux
SBF Files*
Android 2.2 System Version 2.3.15 (the_gift2)
Android 2.2.1 System Version 2.3.320 Full (Happy_Holidays_From_TBH)
Android 2.2.1 System Version 2.3.340 System Only (SHADO_X6_2.3.34_SYSTEM-ONLY)
Android 2.2.1 System Version 2.3.340 Full (VRZ_MB810_2.3.34_1FF_01)
Thanks 1KDS! Check out the Full SBF Site -> http://sites.google.com/site/1kdsdroidx/
DO NOT PROCEED UNLESS YOUR BATTERY IS @ 80% OR HIGHER. YOU HAVE BEEN WARNED.
***Instructions***
- Unzip the sbf to a working/temp folder
- Open RSD Lite, tap the “…” button
- Select the SBF file that you just unzipped
a- Now we need to boot your phone into bootloader
b- With your phone Powered OFF do the following
c- HOLD the Volume Down Button + Camera Button + Power Button
d- You should see a small screen flash.. once u do release the buttons
- You should now see your phone in RSD Lite.
- You may need to click show devices in RSD Lite.
- Click the start button and allow your phone to flash the sbf
- Wait for the proccess to complete and then unplug your phone.
- Now reboot your phone Good Job your all done!
e- When you boot your phone up for the first time you might get stuck in a boot loop NO WORRIES!
f- If stuck in a boot loop do the following!
- When you boot for the first time you may get stuck
g- Pull the battery out of the phone.
h- Replace battery and then do the following with the phone powered OFF
i- HOLD Home and turn the Phone On. When you see an android with a exclamation mark Release HOME and press the Search Button.
- Use the volume up/down buttons to highlight the option “wipe data/factory reset”
- Press the camera button to select it
- When it finishes choose the option to reboot your phone
- That's it you are now back to stock
Credit -> Overfiendx/RoOoLeR
Source: http://androidforums.com/droid-x-al...ide-root-unroot-backup-rom-sbf-overclock.html
The SBF really isn't as hard as you think. Funny Story, I bricked my phone last Friday in my schools union. None the less, I just asked for someone with a PC and voila! Fixed my phone in about 15 minutes. Took longer to Download everything than anything else!
i was still on non rooted GB leak until last night. I finally pulled the trigger and sbf'ed using Roolers guide, went through all the steps to get me to Pre Rooted GB. Everything worked like a champ the first time. That was the first time i sbf'd and like Thats said its not that bad at all.
Not to bad when you actually do it...everyone has the initial fear of the unknown
Yeah, the hardest part about using RSD Lite and an sbf file is putting the X into bootloader mode. ;)
negative ghost rider, its having to deal with the sluggish first boot up with all the bloatware, then waiting for all your apps to install to do anything!
that my friend is the hardest part!
For me the hardest part was getting RSD Lite to run properly. I needed to run it from the command line in the end. Win 7 64-bit.
Not to hijack the thread, but thought I'd ask here since we're talking about SBF. I SPF'd for the first time the other day and was successful but have a quick question. After I let RSD Lite do its thing, RSD Lite progress was at 100%. However I never got a finished status and if I tried to close it I would get a warning that it wasn't done and may damage my phone. Meanwhile my phone had immediately rebooted when it got to 100% and was stuck in a boot loop. After about 15 minutes of waiting I decided to just go for it and unplugged my phone. Got everything up and running no problem, but just curious if it's common for RSD Lite to do that at the end or if I just ran into a small hiccup.
i never get a finished status, i get a rebooting phone status, and when it comes to the moto M i remove the battery like it tells you, and put it back hold power and home, and when it powers on let go of power and continue to hold home, until the exclamation point comes up
Yeah that's what I ended up doing. I saw a different walk through with screen shots that showed RSD Lite saying it was finished and mine never did. Good to know thats normal for future reference.
hello all question im trying to go back to stock and in RSD lite in the status field chipset 43 not supported and once i try to start the flash it fails and sayz something about a ini not retrieved or something any ideas???
Okay i'm going to try sbfing how do know what rsd-lite file to pick and what sbf file i'm not understanding that part.
