Root GB home switcher?
CaucasionJ
I have LP and ADW installed but i want to use the original GB home. When i go to Home Switcher it doesn't give me the option to set it as default. I dont want to uninstall LP or ADW just in case i want to switch but for some reason it wont keep the GB home the default and every time i return to the home screen it asks me to switch to the other two.
Moto home fix from the market worked fine for me.
The only issue with home fix or any other home switcher like homesmack is that once you set Blur as your default home, you can't add home screen shortcuts by long pressing on the icon in the app drawer if you have any other launcher installed. It still gives you the option, but no shortcut gets created. You can still add shortcuts by long pressing the home screen itself and navigating through the menus. Of course, if you use a third-party launcher like LauncherPro, this shouldn't be an issue. Just an FYI.
The other option is if you have Titanium Back-up is back-up ADW and LP and then uninstall them and then if you want them later you can just restore your back up from TI. I never restored ADW, but still have it backed up incase I decide I don't like the default launcher.
differently issues switching homes or having multiple launcher on GB. To use blur I had to completely remove all other launcher.
