Droid Ninja
Hello rooting community.
I am a root newbie so bear with me. I am going to attempt to install the rooted GB patch myself. Never done anything like this before so I am a little apprehensive. I am currently running stock froyo with an idiot proof Z4root.
I will be following a combination of the instructions I read in p3droid's page and a post from scary alien where he breaks it down a little better for beginners:
I have already downloaded Blur_Version.2.3.340.MB810.Verizon.en.US-Part1 and Blur_Version.2.3.340.MB810.Verizon.en.US-Part2 from the p3droid link. First question. Do I need to unzip them before I place them on the top level of the sdcard?
Next question. Where can I get Droid 2 Bootstrapper? It gets installed like any other app? When scary alien says "boot into recovery" does he mean just run the app and it will take me where I need to go? Then I assume its just a matter of finding the files on the sdcard and running part 1/2? Rebooting out of recovery is self explanatory I hope.
What is a Nandroid backup and how important of a step is it? Just a security measure?
Thanks in advance for any help you guys/girls give. As I get some responses I will keep this thread updated as I continue my adventure.... or nightmare
1. I downloaded (and verified with AFV, of course) the "method two" files (i.e, the "Patched update.zip (not signed)" files, part1 and part2)
2. Placed them in the top-level / root of my /sdcard
3. Renamed them to make them shorter (the end-part of the file gets cut-off in custom recovery when viewing the files available to flash, so I wanted to make sure that I was flashing part1 before part2)
4. Installed Droid 2 Bootstrapper (first / top button)
5. Booted into recovery (via D2 Bootstrapper) (second / bottom button)
6. Took a Nandroid backup
7. Flashed the part1.zip
8. Flashed the part2.zip
9. Rebooted and started enjoying GingerBread.
