Root Getting Evo Tomorrow best stripped rom
falcon26
Member
I'm getting my new Evo tomorrow. What rom is best for having all the Sprint Bloatware removed, yet keeping the HTC sense stuff? And I assume 1 click root will work with the Evo like it did with my old Incredible..
Thanks
congrats on your new soon to be evo! you will absolutely love it especially after you root it. i like mikfroyo 4.5. it is pretty stripped down and extremely fast and smooth. have you read the rooting for dummies guide yet? i suggest you read it first before doing anything and any questions you have feel free to ask.
The only thing I am worried about is in the guide for dummies it says you have a small chance of losing 4G forever after rooting your phone :-( I really hope that its a very small chance..
I would recommend Mikfroyo 4.5 or Myn 2.2. Those are two of the most popular sense ROM's.
I have flashed tons of ROMs and never lost my 4G. You don't need to worry about it as long as you have a nandroid backup with working 4G. Both Amon RA and Clockworkmod recoveries backup your wimax keys now...
So basically to root and put a custom rom on you do the following:
1. Download and run Revoke which then roots your phone.
2. Download Clockwork Recovery
3. Download Rom Manger
4. Download the Rom you want and install it via Rom Manger and when it
asks you to make a backup you choose yes
5. That's it your done
Is that pretty much it? That's how I did it on my Htc Incredible.
Yep that is basically it. Just make sure you are following the guide to the tee and you should be fine. Good luck!!!
Yeah, those are the basic steps, but:
1) You'll get clockwork as a part of rooting with unrevoked. No need to flash it again. It won't harm anything, but just be aware that you get everything you need from unrevoked - unlocks nand (s-off), roots your current (stock) ROM, gives you a custom recovery (clockwork).
2) ROM manager can be buggy. I recommend you follow the instructions in the rooting for dummies guide for flashing ROMs manually from recovery. Using ROM manager is fine when you're first starting out, but it's not the best option out there. Like others have said, follow instructions, and you'll be fine.
I recommend using MikFroyo 4.5 it is by far one of the best ROMs I have tried, but I have really only tried Myn's and Mik, It is a lot faster than Myn's and will remove almost all of the sprint stuff the only things left is Sprint Hotspot and peep I think. Also the hotspot app is unlocked meaning you can use it without paying Sprint.
Thanks
Are you looking for a "stock" feel? If so, check these ROM's out:
[ROM] 01/26/11 | SPRINT LOVERS | 2.2 | 3.70.651.1 | Radio/Wimax/PRI All-In-One - xda-developers
[Rom] Burnt Droid - 1.4.2 - by netarchy (07-Jan-2011) Updated with 3.70.651.1 base - xda-developers
[ROM] Stock Turbo *New 3.70.651.1 version* 12/20/2010 - xda-developers
