Just grab the SystemUI from svn for the commit before I added Horizontal QS. You'll lose those but get back the Sense Recent Apps. I wasn't expecting to lose it either, so I understand what you're saying.Hey, Cap...
The Sense5 multitasking isn't available for this Rom, right? Not a big problem, but it just look a lot more refine (IMO) than the ICS version.
Now -- I'm just kicking back waiting on Zoe to be finalized.![]()
Yes, the share feature is way cool. And as far as getting something [awesome] means losing something ...then hey, sacrifice sometimes happen.As far as Zoe, having it will mean you lose something else. The HTC Share feature in Gallery is still pretty cool without it, though.
Just to explain a little more clearly to those 'who don't fully understand' exactly what that means ... speaking for my not so tech savvy members. {Wink Wink}Just grab the SystemUI from svn for the commit before I added Horizontal QS
Replace the SystemUI currently in the ROM with this one: https://jewel-jb-4-1-2-sense5.googlecode.com/svn-history/r7/trunk/system/app/SystemUI.apkYes, the share feature is way cool. And as far as getting something [awesome] means losing something ...then hey, sacrifice sometimes happen.
Just to explain a little more clearly to those 'who don't fully understand' exactly what that means ... speaking for my not so tech savvy members. {Wink Wink}![]()
Aww, that's what I'm talking about. My not so tech savvy friend told me to say, Thanks a lot.Replace the SystemUI currently in the ROM with this one: https://jewel-jb-4-1-2-sense5.googlecode.com/svn-history/r7/trunk/system/app/SystemUI.apk
I'm having problems getting this done!Replace the SystemUI currently in the ROM with this one: https://jewel-jb-4-1-2-sense5.googlecode.com/svn-history/r7/trunk/system/app/SystemUI.apk
Easier said than done, I guess.
Much easier than replacing the .apk in the entire Rom with 7zip and reflashing.
EM, you can use ADB to pull and push the new systemUI.apk correct?
Then fix permissions etc.
I will try this out ...FYI - I usually just Mount system in TWRP and do all these types of operations there using the File Manager (under Advanced). It's pretty easy and you don't have to worry about ROM force closures.
Also wiping caches isn't really necessary as the system will detect an APK change and rebuild dalvik for the necessary app. Fixing permissions also does nothing useful (there's a G+ post about that somewhere by Steve Kondik of CM fame, I believe).
Now I'm stuck at the white HTC screen of death unable to boot into TWRP... didn't have a chance to experiment with the above steps. This wasn't caused by your ROM cap.
Edit: Still can't boot into TWRP, but somehow it comes on...and is now showing a screen that requires a Decrypt password -- Anyone know the default password (because i didn't create one), or know a way to get out of this.
So, go into fastboot usb and type in command window, right?Don't panic.
Reset hardware by holding power for 10 seconds.
Plug into PC, go to your sdk tools folder, in command window say -
adb reboot bootloader
Don't panic.
Did all that .... keeps saying, "device not found".Hmmm, reboot your PC. Then hold down the power button on your phone until it reboots. Once the screen goes dark hold the volume down button. Should get you back into the bootloader. Try to connect via fastboot again.
oDid you have Fastboot turned on in settings? (That's referring to booting quickly, not the actual fastboot mode.)
If so, that's going to cause trouble getting you to boot into the bootloader.
Lets try it again.
Hold down power button until phone truly shuts down - at least 10 seconds.
If plugged in to a charger, the led will turn off.
Then hold down the volume down until bootloader boots.
If it powers down and doesn't turn back on after the 10 second reset, then, hold volume down, tap power, keep holding volume down until boot starts.
That ought to put you into the bootloader.
If successful, stop and post back.
Dunno ...not able to pass HTC white screen ...Does locations app work?
Love having footprints back up I can get it to connect to anything.
OK.
If the bootloader is accessible, I think you'll be fine.
Can you get from there to TWRP using volume buttons to navigate, power button to select - Recovery?
Yes...
S-off.Ok.
I think that's a big step forward.
Do a full wipe in TWRP - data, cache, Dalvik and system - and go for a nandroid restore of something that worked before.
I forgot - are you s-on or s-off?
